I am trying to display the values i get from reading a potentiometer (0-1023) in the program called 'processing'.
when I just use Serial.write(integer) and display the value on a line graph in 'processing' the line will max out at 256 and loop back around to 0 as i vary the potentiometer.
I understand that this is because the serial.write can only write in bytes(8 bits) so I would need to package the 16 bit integer into 2 bytes.
i was considering using a union but as you can probably guess i am very new to arduino so i haven't been able to make that work.
here is the code i have tried:
union Data{  uint16_t now; } data;
void setup() {   // put your setup code here, to run once:
    Serial.begin(9600);
    pinMode(A1, INPUT);
void loop() {   // put your main code here, to run repeatedly:
    uint16_t sensorVal = analogRead(A1);
     union Data data;
    data.now = sensorVal;
    Serial.println(data.now);
    //Serial.write(sensorVal);
    delay(10); }
Tom
  • 59
Send the 16-bit value as two 8-bit values (with a start byte as per JRobert's answer):
Serial.write(0xCC); // Send the start byte
Serial.write((sensorVal >> 8) & 0xFF); // Send the upper byte first
Serial.write((sensorVal & 0xFF); // Send the lower byte
Tom
  • 226
You need to send the uint16_t as the two the individual bytes it is composed of, one at a time, in whatever order your Arduino code and the code on the PC agree on: (MSB first, aka, big-endian; or LSB first, aka little-endian).
Since it would be possible for the two devices to get out of sync, you may also want to package up the two bytes with a third, or "start-byte". Pick some fixed value (such as 0xCC) that has a couple of its MSbits set, then the MSB, then the LSB. Your receiver can know to look for that fixed value, then the MSB (which it knows can't have those high bits set because the analog data is only 10-bits), then the LSB (which could have any value).
The PC should only accept a three-byte packet when it has received one that fits that scheme. Otherwise it waits for another 0xCC (or whatever value you choose), collects two more bytes, and tries again.
JRobert
  • 15,407
This may help Transmisor
int valor;
byte val;
Serial.begin(9600); }
valor=analogRead(A0); val=map(valor,0,1023,0,179); Serial.println(val); Serial.write(val); delay(100); }
Receptor
byte mensaje;
int valor;
if (Serial.available()){ mensaje=Serial.read(); valor=mensaje; Serial.print(valor); Serial.println(" "); } }
sempaiscuba
  • 1,042
user90750
I was checking out the documentation for Serial.write()
You can sent out an array of 2 8Bits in the form of Serial.write(buf, len)
Simply create an int buffer, and then use your original integer and do bit shifting. Notice the & 255 used to make sure there are no values beyond 8 bits.
int data = 1000;
short int buf[2];
buf[0] = data & 255;
buf[1] = (data >> 8)  & 255;
Serial.write(buf, 4);
Also, in C, the name of an array is used as the pointer for the first element. So if you look at the documentation for Serial.write(buf,len) again, you will find that you can probably get the pointer for your int value, and write 2 bytes itself!
Serial.write(*data, 2);
or Serial.write(&data, 2)
BikerDude
  • 131
