I'm using the Visual Studio Code extension to develop for Arduino which works great.
It doesn't have a Serial Plotter like the regular Arduino IDE, which I need to debug this project. I can run the Arduino IDE's Serial Plotter alongside Visual Studio Code without too much of a problem.
However, if I try to compile and upload from Visual Studio Code while the Arduino IDE is running, the port is busy (not a surprise):
avrdude: ser_open(): can't open device "/dev/cu.usbmodem14201": Resource busy
An error occurred while uploading the sketch
So I have to keep exiting and relaunching the Arduino IDE every time I build.
Anyone have a suggestion for how to work around this? Using an iMac as development environment.
Joel Spolsky
  • 171
Without very specialized software that can create two new devices with the correct "teeing" policy, it's not going to be possible. Only one program can open a serial port at a time (certainly and have it get anything intelligible out of it...)
I would suggest you may want to add a second serial port. Use an FT232 adaptor to communicate on another serial connection (or a SoftwareSerial connection at a pinch) for your debugging information. You really want a board with more than one serial port for this - or a board with a native USB for programming and a hardware serial port for data communication.
Another alternative is to ditch the serial for programming altogether and program your board through a dedicated programmer, thus leaving your serial port free for data communication.
Majenko
  • 105,851
  • 82
  • 139
Try teleplot extension in vscode
Moose
