char webpage[] PROGMEM = R"=====(
<html>
  <head>
    <script src="https://cdnjs.cloudflare.com/ajax/libs/svg.js/2.6.6/svg.min.js"></script>
  </head>
  <body>
  </body>
</html>
I found a problem when using the raw string literal in Arduino IDE. My code cannot compile if i have http:// link inside the string.
I found that it should be related to how Arduino IDE thought the string after // are comments and during compile time those string are ignored and my codes break.
It looks like the arduino ide's compiler removes all //comment in the code first, before it try to compile the raw string literal and then cause the issue.
As a test I try to debug it by changing my code to https:/-/ the program can be compile as now there is no // in the raw string literal
Is there any workaround?
Ho Chung Law
  • 91
Escape the two quote marks inside the string using a backslash (literal quotes).
Without the escape characters, the URL is "outside" of a string because the quote marks are string delimiters.
<html>
  <head>
    <script src=\"https://cdnjs.cloudflare.com/ajax/libs/svg.js/2.6.6/svg.min.js\"></script>
  </head>
  <body>
  </body>
</html>
jsotola
  • 1,554
char webpage[] PROGMEM = R"=="==(
<html>
  <head>
  </head>
  <body>
  </body>
</html>
inspired by answer provided by @jsotola if i used the syntax like this R"=="==()=="==" the link will become inside the quote. and hence the ide's complier regards it as a string and won't think // is comment and now the code can complie and the link works.
Ho Chung Law
  • 91
The C & C++ compilers don't look for language syntax inside quoted strings (except for character-escapes such as '\n'). That is the point of quoting the string.
This program just compiled Ok for me:
const char webpage[] PROGMEM = R"=====(
<html>
  <head>
  </head>
  <body>
  </body>
</html>
'//' within the string did not cause any problem. Your example did get an error message that the variable 'webpage' had to be const to put it in Flash memory so I added the 'const' keyword, but that is the only change I made.
If you do that, and your compiler is still complaining, there is some other issue than the '//'.
JRobert
  • 15,407
