I am using a KY-005 with an Arduino Uno. I have the knowledge that Arduino can provide a forward current of 40 mA. How can I make it to 55 mA or above upto 60 mA to unlock its full potential, so as to get efficient IR communication without data being distorted at the KY-022 IR receiver?
Asked
Active
Viewed 422 times
First, I think 40 mA to output from a GPIO is not a wise idea, because those are Arduino Pin Current Limitations.
What you can do is:
- The VCC pin can handle 200 mA. So you can use this pin to power your KY-005 and use a transistor to switch it via a GPIO (much less than 40 mA is needed for that).
- Or (high likely not needed): use an external power source and use a transistor in the same way.
For knowing all details about using a transistor this way, google for "transistor as switch".
Michel Keijzers
- 13,014
- 7
- 41
- 58
