I am working on a project where a rotary encoder is generating 0 - 359° output and I am feeding that to a 60 Neopixel ring but I need a way to simplify or come up with a better way of a bunch of if-then-else statements. Here is some sample code.
// NeoPixel Display
  if ((counter >=3) && (counter <=9))
  strip.setPixelColor(0, 255, 0, 0); //set pixel number 1 and set color to red
  strip.show(); //send color to pixel 1 on NeoPixel Ring
else if strip.setPixelColor(0, 0, 0, 0);
        strip.show();
  if ((counter >=10) && (counter <=15))
  strip.setPixelColor(1, 255, 0, 0); //set pixel number 2 and set color to red
  strip.show(); //send color to pixel 2 on NeoPixel Ring
else if strip.setPixelColor(1, 0, 0, 0);
        strip.show();
  if ((counter >=16) && (counter <=21))
  strip.setPixelColor(2, 255, 0, 0); //set pixel number 3 and set color to red
  strip.show(); //send color to pixel 3 on NeoPixel Ring
else if strip.setPixelColor(2, 0, 0, 0);
        strip.show();
Greenonline
  • 3,152
  • 36
  • 48
Bkukuk62
  • 57
You don't use the correct syntax. I assume you mean:
// NeoPixel Display
else
  strip.show();
And similar for the other colors.
First you see there are a lot of occurences of calls to setPixelColor and show. We make a function of this, where the color and the red value is parameterized:
void setPixel(int pixelNumber, int red)
  strip.setPixelColor(pixelNumber, red, 0, 0);
Now we can write your code as
// NeoPixel Display
  setPixel(0, 255);
else
  setPixel(0, 0);
  strip.show();
Now we get rid of the if statements. For the first color this will become:
// NeoPixel Display
setPixel(0, ((counter >= 3) && (counter <= 9)) ? 255 : 0);
Combined with the other colors we get
// NeoPixel Display
setPixel(1, ((counter >= 10) && (counter <= 15)) ? 255 : 0);
setPixel(2, ((counter >= 16) && (counter <= 21)) ? 255 : 0);
  strip.show();
However, the conditions can be simplified by adding them into the function. So we get
// NeoPixel Display
setPixel(0, counter,  3,  9);
setPixel(1, counter, 10, 15);
setPixel(2, counter, 16, 21);
void setPixel(int pixelNumber, int counter, int lowValue, int highValue)
     ((counter >= lowValue) && (counter <= highValue)) ? 255 : 0,
     0, 0);
  strip.show();
If you need to have more checks if a value is in range you can make it a specific function. This will increase the code, but makes it easier to reuse code. So you will get:
// NeoPixel Display
    inRange(counter, lowValue, highValue) ? 255 : 0,
     0, 0);
  strip.show();
int inRange(int counter, int lowValue, int highValue)
   return ((counter >= lowValue) && (counter <= highValue));
Juraj
  • 18,264
  • 49
Michel Keijzers
  • 13,014
  • 41
  • 58
