I'm currently working in a weather station with online recording on Thingspeak. When I send a set of parameters (T, Pressure, Humidity, light), I don't have any problem with sending data. But when I add to the code the rain parameter, the code doesn't send the data. The rain parameter is calculated based on an interrupt, so could this affect my data sending? It is any trick that I can use to solve it?
The code:
#include <Wire.h>
#include <SoftwareSerial.h>
#include <String.h>
SoftwareSerial Sim900Serial(9,11);//Configarión de los pines serial por software: RX, TX
Weather myHumidity;//Create an instance of the humidity sensor
const byte RAIN = 2;
volatile int pulse_counter_ISR;
float mm;
volatile unsigned long raintime, rainlast, raininterval, rain;
float humidity = 0; // [%]
Serial.begin(19200);
Sim900Serial.begin(19200);//Arduino se comunica con el SIM900 a una velocidad de 19200bps
Sim900Serial.println("AT+IPR=19200"); // Tell the SIM900 not to autobaud
Wire.begin();
pinMode(RAIN, INPUT_PULLUP); // input from wind meters rain gauge sensor
digitalWrite(RAIN, HIGH);
myHumidity.begin();
// attach external interrupt pins to IRQ functions
attachInterrupt(0, interrupt_handler, FALLING);
// turn on interrupts
interrupts();
calcWeather();
comandosAT();
delay(600000);
void calcWeather()
//Calc humidity
humidity = myHumidity.getRH();
//Calculate amount of rainfall for the last 10 minutes
mm = pulse_counter_ISR*0.2794;
pulse_counter_ISR = 0;
void comandosAT(){
Sim900Serial.println("AT+CIPSTATUS");//Consultar el estado actual de la conexión
delay(2000);
Sim900Serial.println("AT+CIPMUX=0");//comando configura el dispositivo para una conexión IP única o múltiple 0=única
delay(3000);
mostrarDatosSeriales();
Sim900Serial.println("AT+CSTT=\"internet.simple\"");
delay(1000);
Sim900Serial.println("AT+CIICR");//REALIZAR UNA CONEXIÓN INALÁMBRICA CON GPRS O CSD
delay(3000);
Sim900Serial.println("AT+CIFSR");// Obtenemos nuestra IP local
delay(2000);
Sim900Serial.println("AT+CIPSPRT=0");//Establece un indicador '>' al enviar datos
delay(3000);
Sim900Serial.println("AT+CIPSTART=\"TCP\",\"api.thingspeak.com\",\"80\"");//Indicamos el tipo de conexión, url o dirección IP y puerto al que realizamos la conexión
delay(6000);
Sim900Serial.println("AT+CIPSEND");//ENVÍA DATOS A TRAVÉS DE una CONEXIÓN TCP O UDP
delay(4000);
String datos="GET https://api.thingspeak.com/update?api_key=MYAPIKEY&field1=0" + String(humidity) + "&field2=0" + String(mm);
Sim900Serial.println(datos);//Envía datos al servidor remoto
delay(4000);
Sim900Serial.println((char)26);
delay(5000);//Ahora esperaremos una respuesta pero esto va a depender de las condiones de la red y este valor quizá debamos modificarlo dependiendo de las condiciones de la red
Sim900Serial.println();
Sim900Serial.println("AT+CIPSHUT");//Cierra la conexión(Desactiva el contexto GPRS PDP)
delay(5000);
void mostrarDatosSeriales()//Muestra los datos que va entregando el sim900
while(Sim900Serial.available()!=0)
Serial.write(Sim900Serial.read());
void interrupt_handler()
pulse_counter_ISR = pulse_counter_ISR + 1;
