In the interest of reducing power consumption, I am putting the Arduino into sleep mode between taking sensor readings. However, the data from readings are stored in arrays, and must not be erased when the device enters sleep mode.
For clarity, I am using sleep_mode_pwr_down, and triggering an interrupt using the Watchdog Timer on the ATMega328 chip. See this post for a description of the different sleep modes: What are (or how do I use) the power saving options of the Arduino to extend battery life?
It would be possible to address this issue by writing data to the EEPROM, however, I am unsure whether this is necessary. The question is whether putting the device into sleep_mode_pwr_down erases the dynamic memory?
Specs / Context:
Arduino Uno (ATMega328 chip)
Triz
Generally, Atmega sleep modes do not erase RAM. Their memory is static and as long as voltage (above 2.7V I believe) is applied, data is held.
However, this also depends on how you plan to wake up the device. If it receives a RESET, RAM is cleared and program execution starts from the beginning.
If an enabled interrupt occurs while the MCU is in a sleep mode, the MCU wakes up. The MCU is then halted for four cycles in addition to the start-up time, executes the interrupt routine, and resumes execution from the instruction following SLEEP. The contents of the Register File and SRAM are unaltered when the device wakes up from sleep.
Check out the AVR's sleep modes to see which fits your application best and how to safely wake it up again
mystery
  • 331
