I've connected SD card module to Arduino UNO. I want to use PIN 10 for PWM DC motor control and because of that, I've connected CS pin directly to another pin (A3).
SD card is working properly, but after calling SD.begin(A3), it set PIN 10 to HIGH! Immediately after SD.begin(A3) and set that pin to LOW, but meanwhile the motor took a small rotation.
I've digged into SD.cpp and Sd2Card.cpp, but couldn't find where this problem occured!
Any help appreciated....
The Solution:
Simply call SD.begin(-1) and it doesn't touch PIN10. Hope helps somebody else!
Khalil Laleh
  • 103
Pin 10 is special. It's the hardware chip select pin for SPI. It is integral to the SPI peripheral in the chip.
That pin must be an OUTPUT for SPI to operate as master, or INPUT for it to operate as a slave.
It's a stupid design decision by Atmel if you ask me, but there you go. So basically trying to use SPI at the same time as PWM on pin 10 is "undefined" and to be avoided.
Use a different pin for PWM or if you need more than there are PWM pins available then consider an external PWM control chip.
Just probing around to get more detail on exactly how it all works, this is what I have found:
  • digitalWrite() explicitly disables PWM on a pin.
  • The direction of pin 10 defines the SPI operation as master or slave.
  • analogWrite() sets pinMode(OUTPUT).
  • The SD library calls pinMode(OUTPUT) and digitalWrite(HIGH) on pin 10.
This means that:
  • SD.begin() will terminate any existing PWM on pin 10.
  • Using PWM on pin 10 will force the pin to output rendering SPI slave mode impossible
You should be able to use PWM on pin 10 if, and only if:
  • You use analogWrite() after using SD.begin(), and
  • You never want to use SPI slave mode.
Majenko
  • 105,851
  • 82
  • 139
