#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <ESP8266WiFiMulti.h>
#include <ArduinoJson.h>
#include <ESP8266HTTPClient.h>
#define USE_SERIAL Serial
ESP8266WiFiMulti WiFiMulti;
String url = "http://192.168.31.170/api/mode/qwertyui";
  USE_SERIAL.begin(9600);
  USE_SERIAL.println();
  for (uint8_t t = 4; t > 0; t--) {
    USE_SERIAL.printf("[SETUP] WAIT %d...\n", t);
    USE_SERIAL.flush();
    delay(1000);
  WiFi.mode(WIFI_STA);
  WiFiMulti.addAP("Robotics Incubator", "XXXXXXX");
  // wait for WiFi connection
  if ((WiFiMulti.run() == WL_CONNECTED)) {
    HTTPClient http;
    http.begin(url); //HTTP
    int httpCode = http.GET();
    if (httpCode == 200) {
      // Parsing
      const size_t bufferSize = JSON_OBJECT_SIZE(1) + 50;
      DynamicJsonBuffer jsonBuffer(bufferSize);  //This was not declared error.
      JsonObject& root = jsonBuffer.parseObject(http.getString());
      // Parameters
      int Mode = root["mode"]; // 1
      Serial.print("Name:");
      Serial.println(Mode);
    http.end();
  if (Serial.available()) {
    url = Serial.readString();
  delay(100);
How can I solve this problem? I followed this tutorial - ESP8266: Parsing JSON
per1234
  • 4,278
  • 43
Adnan Sabbir
This error is caused by using a 6.x.x version of the ArduinoJson library with code that was written for a pre-6.x.x version of the library.
You have two options to solve the problem:
A. Downgrade the library to a version that is compatible with your code
For now, this is probably the best option because the 6.x.x version of the ArduinoJson is still in beta so it makes sense to wait until the new API is stabilized before porting your code. This is even recommended by the ArduinoJson developers:
https://arduinojson.org/v5/faq/error-jsonbuffer-was-not-declared-in-this-scope/
  1. Sketch > Include Library > Manage Libraries...
  2. Wait for the download to finish.
  3. In the "Filter your search..." box, type: "arduinojson".
  4. Click on "ArduinoJson by Benoit Blanchon".
  5. From the "Select version" dropdown menu, select "Version 5.13.2".
  6. Click "Update". Wait for the update to finish.
  7. Click "Close".
Now your code will compile. If you have File > Preferences > Check for updates on startup enabled, you will continue to get updatable library notification for the ArduinoJson library but you need to refrain from updating back to a 6.x.x version or the error will come back.
B. Update your code to be compatible with the 6.x.x version of the ArduinoJson library
In this case you need to modify your deserialization code to use the new DynamicJsonDocument instead of the old DynamicJsonBuffer:
  // Parsing
  DynamicJsonDocument jsonDocument(bufferSize);
  DeserializationError error = deserializeJson(jsonDocument, http.getString());
  if (error) {
    Serial.println("There was an error while deserializing");
  else {
    JsonObject root = jsonDocument.as<JsonObject>();
    // Parameters
You can get more details about this here:
https://arduinojson.org/v6/doc/upgrade/
per1234
  • 4,278
  • 43
This answer needs to be updated for anyone who visits here. The 6.x.x is no longer in beta. Simply update to the latest version. At the time of writing this answer the version id is 6.15.2. Updating to this will resolve the error.
ambassallo
  • 101
