I want to wrap a random number using modulo, so that values exceeding 11 starts over from 0 and greater. However, i would also like numbers less than 0 to dividend 11 or less.
Please correct me if i'm wrong, but as far as i can tell the modulo operator only dividends values exceeding the divisor. If so, how can i write code that also dividends values less than 0?
Erik
  • 271
Simply use modulo
#include <stdio.h>
int main(){
   for (int i = -23;i<23;i++) printf("%d    %d\n",i,i%11);
   return 0;
all modern C variants should work the same way https://en.wikipedia.org/wiki/Modulo_operation (result have same sign as divident):
-23 -1
-22 0
-21 -10
-20 -9
-19 -8
-18 -7
-17 -6
-16 -5
-15 -4
-14 -3
-13 -2
-12 -1
-11 0
-10 -10
-9  -9
-8  -8
-7  -7
-6  -6
-5  -5
-4  -4
-3  -3
-2  -2
-1  -1
0   0
1   1
2   2
3   3
4   4
5   5
6   6
7   7
8   8
9   9
10  10
11  0
12  1
13  2
14  3
15  4
16  5
17  6
18  7
19  8
20  9
21  10
22  0
for new formulation of request fixed by @Gerben suggestion
if you want monotonic 0..10 sequencies, add 11, if result is negative :
#include <stdio.h>
int main(){
    int x= i%11 ;
    x += x<0?11:0;
    printf("    %d  %d\n",i,x);
return 0;
results in
-23 10
-22 0
-21 1
-20 2
-19 3
-18 4
-17 5
-16 6
-15 7
-14 8
-13 9
-12 10
-11 0
-10 1
-9  2
-8  3
-7  4
-6  5
-5  6
-4  7
-3  8
-2  9
-1  10
0   0
1   1
2   2
3   3
4   4
5   5
6   6
7   7
8   8
9   9
10  10
11  0
12  1
13  2
14  3
15  4
16  5
17  6
18  7
19  8
20  9
21  10
22  0
gilhad
  • 1,466
One crude way:
while (x > 11) x -= 11;
while (x < 0) x += 11;
The first could be replaced with a modulo operation.
Majenko
  • 105,851
  • 82
  • 139
