I've got 2 "Mega + WiFi R3 ATmega2560 + ESP8266" (link) and both have same issue when trying to use the ESP chip.
Hope someone can point me toward something else to try in order to get them working properly.
Context
I'm able to flash the ESP chip using Arduino IDE or PlatformIO. Dip switch need to be : 5, 6 and 7 ON to flash, and only 5 and 6 to debug through serial.
I've tried using different boards (Generic ESP8266 module, Wemos D1 R2 & mini, Node MCU) as well as different flash mode (DIO, QIO), crystal frequency (26 Mhz, 40 Mhz), CPU frequency (80 Mhz, 160 Mhz)
They all flash correctly without any error and I can get my serial output.
It's written ESP8266EX on the ESP chip. And I've tried with or without an antenna plugged on the board.
Problem
The problem I got on both of them is huge instability when using wifi. I cannot connect to them when they are in AP mode, they drop immediately.. And I cannot connect to or see my own wifi network from the Mega's ESP.
The same script and flashing config used on other ESPs devices work as expected (see [output other ESP board] below). I've tried on WeMos and NodeMCU devices.
But with the mega+wifi, it only see between 0 and 2 access point that are at a greater distance and weaker signal than my own wifi ([output mega+wifi] below).
I don't have any clue on what can cause such a different result on device from same family (ESP/espressif). As if there was some sort of setting that need to be changed on those ESPs.
Any help or insight would be truly appreciated.
[code]
#include "ESP8266WiFi.h"
Serial.begin(115200);
// Set WiFi to station mode and disconnect from an AP if it was previously connected
WiFi.mode(WIFI_STA);
WiFi.disconnect();
delay(100);
Serial.println("Setup done");
Serial.println("scan start");
// WiFi.scanNetworks will return the number of networks found
int n = WiFi.scanNetworks();
Serial.println("scan done");
if (n == 0)
Serial.println("no networks found");
else
Serial.print(n);
Serial.println(" networks found");
for (int i = 0; i < n; ++i)
// Print SSID and RSSI for each network found
Serial.print(i + 1);
Serial.print(": ");
Serial.print(WiFi.SSID(i));
Serial.print(" (");
Serial.print(WiFi.RSSI(i));
Serial.print(")");
Serial.println((WiFi.encryptionType(i) == ENC_TYPE_NONE)?" ":"*");
delay(10);
Serial.println("");
// Wait a bit before scanning again
delay(5000);
scandone
scan done
8 networks found
1: 412 Precondition Failed (-67)*
2: VIDEOTRON1547 (-90)*
3: BELL275 (-94)*
4: BELL558 (-72)*
5: C-PC_Network (-88)*
6: BELL387 (-90)*
7: EBOX-4229 (-94)*
8: VIDEOTRON6825 (-80)*
scan start
scandone
scan done
11 networks found
1: 412 Precondition Failed (-63)*
2: VIDEOTRON1547 (-88)*
3: BELL681 (-90)*
4: BELL275 (-90)*
5: VIDEOTRON0442 (-90)*
6: BELL558 (-71)*
7: BELL602 (-90)*
8: IKA COIFFURE (-90)*
9: C-PC_Network (-87)*
10: EBOX-4229 (-87)*
11: BELL387 (-90)*
scan start
scandone
scan done
7 networks found
1: 412 Precondition Failed (-65)*
2: BELL681 (-88)*
3: VIDEOTRON1547 (-88)*
4: EBOX-4229 (-88)*
5: BELL387 (-87)*
6: BELL558 (-71)*
7: dlink-Ares (-75)*
[output mega+wifi]
SDK:2.2.1(cfd48f3)/Core:2.4.1/lwIP:2.0.3(STABLE-2_0_3_RELEASE/glue:arduino-2.4.1)
bcn 0
del if1
usl
mode : sta(2c:3a:e8:26:36:13)
add if0
wifi evt: 8
Setup done
scan start
scandone
scan done
1 networks found
1: BELL558 (-69)*
scan start
scandone
scan done
1 networks found
1: BELL387 (-88)*
scan start
scandone
scan done
no networks found
scan start
scandone
scan done
1 networks found
1: BELL387 (-87)*
[erasing flash]
PS \tool-esptoolpy> python .\esptool.py -p COM10 erase_flash
esptool.py v2.3.1
Connecting....
Detecting chip type... ESP8266
Chip is ESP8266EX
Features: WiFi
Uploading stub...
Running stub...
Stub running...
Erasing flash (this may take a while)...
Chip erase completed successfully in 14.2s
Hard resetting via RTS pin...
