I have problem with my esp8266 it connects to my site and sends 89 bytes of data but does return a confirmation status all i get is SEND OK but i don't get any confirmation from my server
This is my code below
 #include <SoftwareSerial.h>
#include<time.h>
SoftwareSerial ESP8266(3, 2); // RX, TX
//DEFINE ALL GLOBAL VAARIABLES HERE
unsigned int timeout_start_val;
char scratch_data_from_ESP[20];//first byte is the length of bytes
char payload[150];
byte payload_size=0, counter=0;
char ip_address[16];
char youtube_subs[10];
char youtube_views[13];
char current_temp[5];
char hi_temp[5];
char lo_temp[5];
//MODES
const char CWMODE = '3';//CWMODE 1=STATION, 2=APMODE, 3=BOTH
const char CIPMUX = '1';//CIPMUX 0=Single Connection, 1=Multiple Connections
//PASS word
const char SSID_ESP[]="Xamel";//"AOTEA TZ";//from constant
const char SSID_KEY[]="cewu5103";//"wyrnC592";
//DEFINE KEYWORDS HERE
const char keyword_OK[]="OK";
const char keyword_FAIL[]="FAIL";
const char keyword_Ready[] = "Ready";
const char keyword_no_change[] = "no change";
const char keyword_blank[] = "#&";
const char keyword_ip[] = "192.";
const char keyword_rn[] = "\r\n";
const char keyword_quote[] = "\"";
const char keyword_carrot[] = ">";
const char keyword_sendok[] = "SEND OK";
const char keyword_linkdisc[] = "Unlink";
const char keyword_CHECKCWMODE[] = "+CWMODE:3";
const char keyword_URL_CONNECTION_ERROR[]="Link typ ERROR";
const char TEST_URL[]="";
const char GET_URL[]="GET /ESP8266_BackEnd/SaveDetail.php?Name=";
int str1=strlen(GET_URL);
const char Name[]="Alex ";
int str2=strlen(Name);
const char TRAILING_URL[]="HTTP/1.1 \\r\\nHost: www.pick2get.com\\r\\n\\r\\n";
int str3=strlen(TRAILING_URL);
int strTotal=str1+str2+str3;
const char AT_CIPSTART[]="AT+CIPSTART=4,\"TCP\",\"pick2get.com\",80 \r\n";
const char AT_CIPSEND[]="AT+CIPSEND=4,";
//function prototype
boolean read_until_ESP(const char keyword1[], int key_size, int timeout_val, byte mode);
void serial_dump_ESP();
boolean setup_ESP(const char SSID_ESP[],const char SSID_KEY);
String url="&School=4D616B6F6E676F";
  // Open serial communications and wait for port to open:
  Serial.begin(9600);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  //.print("Total string length");Serial.println(strTotal);
  // set the data rate for the SoftwareSerial port
  ESP8266.begin(9600);
  //Serial.println(read_until_ESP(keyword_URL_CONNECTION_ERROR,sizeof(keyword_URL_CONNECTION_ERROR),5000,0));
  setup_ESP(SSID_ESP,SSID_KEY);
  ESP8266.print(AT_CIPSTART);
  ESP8266.print("");
  delay(1000);
  ESP8266.print(AT_CIPSEND);
  ESP8266.print(strTotal);
  ESP8266.print("\r\n");
  delay(1000);
  ESP8266.print("");
  ESP8266.print(GET_URL);
  ESP8266.print(Name);
  ESP8266.print(TRAILING_URL);
  delay(1000);
  ESP8266.print("");
  //ESP8266.println("&Grade=466F726D204F6E65");
  //ESP8266.println("&DeviceIP=3139322E3136382E302E31");
  //ESP8266.println(TRAILING_URL);
void loop() { // run over and over
  byte buffer[300];
  if (ESP8266.available()) {
   Serial.write(ESP8266.read());
  if (Serial.available()) {
    ESP8266.write(Serial.read());
This is the output generated on the serial monitor
ESP CHECK OK
ESP RESET OK
ESP RESET OK
timeout
ESP CWMODE SET FAILED
CWMODE ALREADY SET
SETTING SSID_ESP: Xamel
SETTING SSID_KEY: cewu5103
ESP SSID SET OK DEVICE CONNECTED
CHECKING FOR AN IP ADDRESS
IP ADDRESS = 192.168.4.1
ESP CIPMUX SET
AT+CIPSTART=4,"TCP","pick2get.com",80
OK
Linked
AT+CIPSEND=4,89
> GET /ESP8266_BackEnd/SaveDetail.php?Name=Alex HTTP/1.1 \r\nHost: www.pick2get.com\r\n\r\n
SEND OK
OK
Unlink
Can any one please help here.
When adding ESP8266.print("+IPD\r\n"); this is the output i get
    ESP CHECK OK
ESP RESET OK
ESP RESET OK
timeout
CWMODE ALREADY SET
ESP CIPMUX SET
AT+CIPSEND=4,89
busy p...
OK
Linked
wrong syntax
ERROR
AT+IPD
ERROR
I have managed to fix the lack of server response by removing the \r\n \nd replacing them with regular \r\n\r\n
enter code here
const char TRAILING_URL[]="HTTP/1.1 \r\nHost: www.pick2get.com \r\n\r\n";
At this lines and was able to get a server response
+IPD,4,392:HTTP/1.1 400 Bad Request Date: Tue, 15 May 2018 12:07:08 GMT Server: Apache Content-Length: 226 Connection: close Content-Type: text/html; charset=iso-8859-1
400 Bad Request Bad Request
Your browser sent a request that this server could not understand.
finally i have debugged and fixed all the errors and the code works just fine This and server returns a status 200
turns out it was just me pointing GET request in the wrong folder path with this line code at in the GET_URL variable
const char GET_URL[]="GET pick2get.com/ESP8266_BackEnd/SaveDetail.php?Name=";
I replaced with this
And got the desired result
+IPD,4,166:HTTP/1.1 200 OK Date: Tue, 15 May 2018 12:2249 GMT Server: Apache Upgrade: h2 Connection: Upgrade Transfer-Encoding: chunked Content-Type: text/html
OK
+IPD,4,191:16 Connected successfully 5c DATA TRANSMITTED SUCSSEFULLYSTUDENT NAME RECIVED: Alex
STUDENT SCHOOL NAME RECIVED:
3b STUDENT GRADE RECIVED:
DEVICE IP ADDREESS RECIVED:
OK
+IPD,4,42:1f New record created successfully 0 Thanks a lot guys below is the complete working code
  Software serial multple serial test
 Receives from the hardware serial, sends to software serial.
 Receives from software serial, sends to hardware serial.
 The circuit:
 * RX is digital pin 10 (connect to TX of other device)
 * TX is digital pin 11 (connect to RX of other device)
 Note:
 Not all pins on the Mega and Mega 2560 support change interrupts,
 so only the following can be used for RX:
 10, 11, 12, 13, 50, 51, 52, 53, 62, 63, 64, 65, 66, 67, 68, 69
 Not all pins on the Leonardo and Micro support change interrupts,
 8, 9, 10, 11, 14 (MISO), 15 (SCK), 16 (MOSI).
 created back in the mists of time
 modified 25 May 2012
 by Nolawi solomon
#include<time.h>
char payload[150];
//MODES
//PASS word
//const char TEST_URL[]="";
const char TRAILING_URL[]="HTTP/1.1\r\nHost: www.pick2get.com \r\n\r\n";
//String url="&School=4D616B6F6E676F";
  Serial.begin(9600);
  while (!Serial) {
  ESP8266.print("");
  delay(1000);
  delay(1000);
  ESP8266.print("");
  //delay(3000);
  //ESP8266.print("");
  //delay(2000);
  //ESP8266.print("\r\n");
  //delay(2000);
  //ESP8266.print("AT+IPD\r\n");
  byte buffer[300];
boolean read_until_ESP(const char keyword1[], int key_size, int timeout_val, byte mode){
  timeout_start_val=millis();//for the timeout
  char data_in[20];//this is the buffer - if keyword is longer than 20, then increase this
  int scratch_length=1;//the length of the scratch data array
  key_size--;//since we're going to get an extra charachter from the sizeof()
 //FILL UP THE BUFFER
 for(byte i=0; i<key_size; i++){//we only need a buffer as long as the keyword
            //timing control
            while(!ESP8266.available()){//wait until a new byte is sent down from the ESP - good way to keep in lock-step with the serial port
              if((millis()-timeout_start_val)>timeout_val){//if nothing happens within the timeout period, get out of here
                Serial.println("timeout");
                return 0;//this will end the function
              }//timeout
            }// while !avail
    data_in[i]=ESP8266.read();// save the byte to the buffer 'data_in[]
    if(mode==1){//this will save all of the data to the scratch_data_from
      scratch_data_from_ESP[scratch_length]=data_in[i];//starts at 1
      scratch_data_from_ESP[0]=scratch_length;// [0] is used to hold the length of the array
      scratch_length++;//increment the length
    }//mode 1
  }//for i
//THE BUFFER IS FULL, SO START ROLLING NEW DATA IN AND OLD DATA OUT
  while(1){//stay in here until the keyword found or a timeout occurs
     //run through the entire buffer and look for the keyword
     //this check is here, just in case the first thing out of the ESP was the keyword, meaning the buffer was actually filled with the keyword
       if(keyword1[i]!=data_in[i])//if it doesn't match, break out of the search now
       break;//get outta here
       if(i==(key_size-1)){//we got all the way through the keyword without breaking, must be a match!
       return 1; //return a 1 and get outta here!
       }//if
     }//for byte i
    //start rolling the buffer
    for(byte i=0; i<(key_size-1); i++){// keysize-1 because everthing is shifted over - see next line
      data_in[i]=data_in[i+1];// so the data at 0 becomes the data at 1, and so on.... the last value is where we'll put the new data
    }//for
           //timing control
            while(!ESP8266.available()){// same thing as done in the buffer
                return 0;
              }//timeout
            }// while !avail
    data_in[key_size-1]=ESP8266.read();//save the new data in the last position in the buffer
      if(mode==1){//continue to save everything if thsi is set
      scratch_data_from_ESP[scratch_length]=data_in[key_size-1];
      scratch_length++;
    }//mode 1
    /*  JUST FOR DEBUGGING
    if(ESP8266.overflow())
    Serial.println("*OVER");
  }//while 1
}//read until ESP
boolean setup_ESP(const char SSID_ESP[],const char SSID_KEY[]){//returns a '1' if successful
  ESP8266.print("AT\r\n");// Send just 'AT' to make sure the ESP is responding
  //this read_until_... function is used to find a keyword in the ESP response - more on this later and in the function itself
  if(read_until_ESP(keyword_OK,sizeof(keyword_OK),5000,0))//go look for keyword "OK" with a 5sec timeout
    Serial.println("ESP CHECK OK");
  else
    Serial.println("ESP CHECK FAILED");
  serial_dump_ESP();//this just reads everything in the buffer and what's still coming from the ESP
   ESP8266.print("AT+RST\r\n");// Give it a reset - who knows what condition it was in, better to start fresh
  if(read_until_ESP(keyword_Ready,sizeof(keyword_Ready),5000,0))//go look for keyword "Ready" - takes a few seconds longer to complete
    Serial.println("ESP RESET OK");//depneding on the FW version on the ESP, sometimes the Ready is with a lowercase r - ready
  else
    Serial.println("ESP RESET FAILED");
  serial_dump_ESP();
  else
  serial_dump_ESP();
   ESP8266.print("AT+CWMODE=");// set the CWMODE
   ESP8266.print(CWMODE);//just send what is set in the constant
  if(read_until_ESP(keyword_OK,sizeof(keyword_OK),1000,0))//go look for keyword "OK"
    Serial.println("ESP CWMODE SET");
  else
    Serial.println("ESP CWMODE SET FAILED");//probably going to fail, since a 'no change' is returned if already set - would be nice to check for two words
    ESP8266.println("AT+CWMODE?");
    if(read_until_ESP(keyword_CHECKCWMODE,sizeof(keyword_CHECKCWMODE),1000,0))
      Serial.println("CWMODE ALREADY SET");
      serial_dump_ESP();
    serial_dump_ESP();
   //Here's where the SSID and PW are set
   Serial.print("SETTING SSID_ESP: ");
   Serial.println(SSID_ESP);
   Serial.print("SETTING SSID_KEY: ");
   Serial.println(SSID_KEY);
   //DEbug poin
   ESP8266.print("AT+CWJAP=");//
   ESP8266.print("\"");
   ESP8266.print(SSID_ESP);//
   ESP8266.print("\",\"");
   ESP8266.print(SSID_KEY);//
   ESP8266.print("\"\r\n");
  if(read_until_ESP(keyword_OK,sizeof(keyword_OK),5000,0)==1)//go look for keyword "OK"
    Serial.println("ESP SSID SET OK DEVICE CONNECTED");
  else if(read_until_ESP(keyword_FAIL,sizeof(keyword_FAIL),5000,0)==1)
    Serial.println("ESP SSID SET FAILED");
  serial_dump_ESP();
  //This checks for and stores the IP address
  Serial.println("CHECKING FOR AN IP ADDRESS");
  ESP8266.print("AT+CIFSR\r\n");//command to retrieve IP address from ESP
  if(read_until_ESP(keyword_rn,sizeof(keyword_rn),10000,0)){//look for first \r\n after AT+CIFSR echo - note mode is '0', the ip address is right after this
  if(read_until_ESP(keyword_rn,sizeof(keyword_rn),1000,1)){//look for second \r\n, and store everything it receives, mode='1'
    //store the ip adress in its variable, ip_address[]
    for(int i=1; i<=(scratch_data_from_ESP[0]-sizeof(keyword_rn)+1); i++)//that i<=... is going to take some explaining, see next lines
       ip_address[i] = scratch_data_from_ESP[i];//fill up ip_address with the scratch data received
//i=1 because i=0 is the length of the data found between the two keywords, BUT this includes the length of the second keyword, so i<= to the length minus
//size of teh keyword, but remember, sizeof() will return one extra, which is going to be subtracted, so I just added it back in +1
    ip_address[0] = (scratch_data_from_ESP[0]-sizeof(keyword_rn)+1);//store the length of ip_address in [0], same thing as before
    Serial.print("IP ADDRESS = ");//print it off to verify
    for(int i=1; i<=ip_address[0]; i++)//send out the ip address
    Serial.print(ip_address[i]);
    Serial.println("");
  }}//if first \r\n
  else
  Serial.print("IP ADDRESS FAIL");
  serial_dump_ESP();
   ESP8266.print("AT+CIPMUX=");// set the CIPMUX
   ESP8266.print(CIPMUX);//from constant
  if(read_until_ESP(keyword_OK,sizeof(keyword_OK),5000,0))//go look for keyword "OK" or "no change
    Serial.println("ESP CIPMUX SET");
  else
    Serial.println("ESP CIPMUX SET FAILED");
  serial_dump_ESP();
 //that's it!  Could be done by nesting everything together, so if one thing fails, it returns '0', and if it gets all the way through it returns '1'...oh well
}//setup ESP
//pretty simple function - read everything out of the serial buffer and whats coming and get rid of it
void serial_dump_ESP(){
  char temp;
  while(ESP8266.available()){
    temp =ESP8266.read();
    delay(1);//could play around with this value if buffer overflows are occuring
  }//while
}//serial dump
Charles
  • 99
You need to have "Connection: keep-alive" in your http header, default is "Connection: close" and that's why you never get anything in return from the server.
I have described it all together with a code sample in https://arduino.stackexchange.com/a/54558/48149
The code sample uses the library WifiEsp to connect to ESP8266.
