I am writing a speedo/odometer program which was all working beautifully until I introduced an LCD screen and code for the LCD.
The screen works on power up, displays the distance recorded on an SD card, toggles from miles to km on the press of a button, but no longer runs my calculate method when invoked. The method has stopped working, or at least it's not updating with the latest information anymore when the method instructs it to. Any help would be greatly appreciated.
In case it matters, I am powering the project from an HTC one M8. Maybe it's lack of juice that is causing the issue, or just bad programming?
My code:
#include <Arduino.h>
#include <SPI.h>
#include <SD.h>;
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
int InterruptPin = 2;
//int PowerPin = 3;
int ButtonPin = 4;
int SDPin = 7;
volatile long km = 0; // SAVE
volatile float kmTemp = 0; // SAVE
volatile int kmrevs = 0; // SAVE
volatile long miles = 0; // SAVE
volatile float milesTemp = 0; // SAVE
volatile int milesrevs = 0; // SAVE
volatile int kph = 0;
volatile int mph = 0;
volatile unsigned long start = 0;
volatile unsigned long stop = 0;
volatile float secs = 0;
volatile float speed = 0;
volatile float temp = 0;
volatile int buttonState = 0;
volatile int lastButtonState = 0;
volatile boolean riding = false;
File myFile;
LiquidCrystal_I2C lcd(0x27, 16, 2);
void calculate(){
    riding = true;
    // KPH SPEED CALCULATOR
    stop = millis() - start;
    start = millis();
    temp = (float)stop;
    secs = temp / 1000;
    speed = 1.854 / secs;
    speed = speed * 3.6;
    kph = speed;
    // MPH SPEED CONVERTOR
    float x = kph * 0.6214;
    mph = x;
    // KM DISTANCE CALCULATOR
    kmrevs++;
    if (kmrevs == 540){
        km++;
        kmrevs = 0;
        kmTemp = kmTemp + 0.00116;
    if (kmTemp >= 1.0){
        km++;
        kmTemp = kmTemp - 1.0;
    // MILES DISTANCE CALCULATOR
    milesrevs++;
    if (milesrevs == 868){
        miles++;
        milesrevs = 0;
        milesTemp = milesTemp +0.072;
    if (milesTemp >= 1.0){
        miles++;
        milesTemp = milesTemp - 1.0;
    // PRINT DATA TO LCD & SERIAL
    buttonState = digitalRead(ButtonPin);
    if (buttonState == HIGH){
        lastButtonState = buttonState;
        Serial.print(kph);
        Serial.print("kph  ");
        Serial.print(km);
        Serial.print("km  (");
        Serial.print(kmTemp, 6);
        Serial.println(")  ");
        lcd.clear();
        lcd.setCursor(0,0);
        lcd.print(kph);
        lcd.print("kph");
        lcd.setCursor(0,1);
        lcd.print(km);
        lcd.print("km");
    if (buttonState == LOW){
        Serial.print(mph);
        Serial.print("mph  ");
        Serial.print(miles);
        Serial.print("miles  (");
        Serial.print(milesTemp, 6);
        Serial.println(")");
        lcd.clear();
        lcd.setCursor(0,0);
        lcd.print(mph);
        lcd.print("mph");
        lcd.setCursor(0,1);
        lcd.print(miles);
        lcd.print("miles");
    // SAVE DATA TO SD CARD
    SD.remove("test.txt");
myFile = SD.open("test.txt", FILE_WRITE);
    if (myFile) {
        myFile.print(km);
        myFile.print(" ");//
        myFile.print(kmTemp, 6);
        myFile.print(kmrevs);
        myFile.print(miles);
        myFile.print(milesTemp, 6);
        myFile.print(milesrevs);
        myFile.close();
    else {
        // SD SAVE ERROR
        Serial.println("Save Error");
void setup(){
    pinMode(ButtonPin, INPUT_PULLUP);
    pinMode(InterruptPin, INPUT);
    // POWER LCD SCREEN
    //lcd.begin(16,2);
    lcd.init();
    lcd.backlight();
    // LAUNCH SERIAL CONNECTION
    Serial.begin(9600);
    // LOAD DATA FROM SD CARD
    SD.begin(7);
    myFile = SD.open("test.txt", FILE_READ);
    if (myFile) {
       while (myFile.available()) {
       km = myFile.parseInt();
       kmTemp = myFile.parseFloat();
       kmrevs = myFile.parseInt();
       miles = myFile.parseInt();
       milesTemp=myFile.parseFloat();
       milesrevs = myFile.parseInt();
    myFile.close();
    else {
        Serial.println("Read Error");
    // ATTACH INTERRUPTS
     attachInterrupt(digitalPinToInterrupt(2), calculate, RISING);
    // LOAD START SERIAL & LCD SPEED
        // MPH DISPLAYED
        Serial.print("0mph  ");
        lcd.clear();
        lcd.setCursor(0,0);
        lcd.print(mph);
        lcd.print("mph");
        lcd.setCursor(0,1);
        lcd.print(miles);
        lcd.print("miles");
        // KPH DISPLAYED
        Serial.print("0kph  ");
        Serial.print(km);
        lcd.clear();
        lcd.setCursor(0,0);
        lcd.print(kph);
        lcd.print("kph");
        lcd.setCursor(0,1);
        lcd.print(km);
        lcd.print("km");
void loop(){
    // ZERO SPEED ON SLOW ROTATION
    if (riding == true){
    long period = millis() - start;
    if (period == 4150){
        // MPH DISPLAYED
        lcd.clear();
        lcd.setCursor(0,0);
        lcd.print(mph);
        lcd.print("mph");
        lcd.setCursor(0,1);
        lcd.print(miles);
        lcd.print("miles");
        // KPH DISPLAYED
        Serial.print(km);
        lcd.clear();
        lcd.setCursor(0,0);
        lcd.print(kph);
        lcd.print("kph");
        lcd.setCursor(0,1);
        lcd.print(km);
        lcd.print("km");
    // CHANGE READING WHEN PRESSED
    if (buttonState != lastButtonState){
        if (buttonState == HIGH && period < 4150){
        // KPH DISPLAYED
        Serial.print(kph);
        Serial.print(km);
        lcd.clear();
        lcd.setCursor(0,0);
        lcd.print(kph);
        lcd.print("kph");
        lcd.setCursor(0,1);
        lcd.print(km);
        lcd.print("km");
        if (buttonState == HIGH && period > 4150){
        // KPH DISPLAYED
        Serial.print(km);
        lcd.clear();
        lcd.setCursor(0,0);
        lcd.print(kph);
        lcd.print("kph");
        lcd.setCursor(0,1);
        lcd.print(km);
        lcd.print("km");
    if (buttonState == LOW && period < 4150){
        // MPH DISPLAYED
        Serial.print(mph);
        lcd.clear();
        lcd.setCursor(0,0);
        lcd.print(mph);
        lcd.print("mph");
        lcd.setCursor(0,1);
        lcd.print(miles);
        lcd.print("miles");
    if (buttonState == LOW && period > 4150){
        // MPH DISPLAYED
        lcd.clear();
        lcd.setCursor(0,0);
        lcd.print(mph);
        lcd.print("mph");
        lcd.setCursor(0,1);
        lcd.print(miles);
        lcd.print("miles");
user4163554
  • 49
Thanks guys, taking the labour out of the ISR has solved the problem perfectly. Unfortunately, the advice wasn't given as an answer so I'm unable to credit you for it, but appreciate the solutions given. Thanks.
user4163554
  • 49
