let's suppose I have folder called AES, in this folder is file "AES.ino" where is code and folder "AESLib" what is library. In "AESLib" is file called "AESLib.h",
now when I try to include AESLib.h with
#include "AESLib/AESLib.h"
in my AES.ino, then Arduino command line tool complain that its not able to find "AESLib.h"
Where could be the catch?
Thanks
xrep
I have the same problem using the Arduino IDE 1.5.6 beta. Adding the library(s) using the menu (Sketch->include library->something) makes it work until the IDE is closed.
Maybe this similar post is what you are looking for. In your case, you should use the path to the sketch folder as 'PROJECT_ROOT'.
Here's the link: https://arduino.stackexchange.com/a/9575/7741
Hope it helps.
