When interfacing my Arduino Uno with a relay I was facing reliability issues, and while investigating it with a multimeter, I found something strange.
I noticed that in the 5V power pin (with which I was powering my circuit) is producing only 3.3V when using the power adapter. However, when connected via the USB-A port, the 5V pin was producing the expected 5V voltage.
I tried powering it in many ways - computer-to-USB-A, computer-to-barrel-jack, phone-charger-to-USB-A, phone-charger-to-barrel-jack and an external 5V DC power supply. In all cases, the above observation held true - powering the board through the barrel jack made the 5V power pins produce only 3.3V.
Question: Why is this happening? Does that mean my board is faulty? Is there any way to fix this?
jrharshath
  • 133
OK, assuming you are putting 5V into the barrel jack this is exactly what you expect to happen.
From the Arduino Uno specifications you are supposed to supply a recommended 7V to 12V. Your supply of 5V is too low.
The barrel jack first goes through a M7 protection diode which would have about a 0.7V forward voltage drop, and then through a NCP1117ST50T3G voltage regulator which has a dropout voltage of (typically) 0.95V at 100 mA.
Thus you have:
5V input - 0.7V - 0.95V = 3.35V
That is what you are finding.
Solutions
  • If you have a proper, regulated, 5V DC supply you can put that directly onto the 5V pin of the Arduino. Better get the wires around the right way because you are bypassing the protection diode!
  • Get a DC supply in the range 7V to 12V and put that into the barrel jack.
  • Another simple idea is to just get a wall-wart that is used for charging phones via USB and run a USB cable into the Arduino USB port.
Empirical test
I put 5V into the barrel jack of my Uno and read 3.33V on the 5V pin, which is pretty-much what you got. I measured a 0.77V drop over the M7 diode.
Nick Gammon
  • 38,901
While Nick's answer is 100% (technically) correct. Functionally, it's a much easier story (given you feed 5V into the barrel jack).
Check the Arduino's product page.
Microcontroller ATmega328P
Operating Voltage   5V
Input Voltage (recommended) 7-12V
So yes, while the Arduino runs on 5V (and does so over USB). The recommended input voltage is 7-12V. You're simply not supplying a high enough voltage.
The difference, as per Nick's answer, is the protection circuit and regulator snooping off a few volts (which is bypassed when using USB).
aaa
  • 2,715
  • 25
  • 40
