I'm trying to communicate with an MPU6500 sensor via SPI as I need the fastest possible update rate. I have trouble finding an easy to understand sample code, or perhaps a lightweight library how to configure and initialize the sensor and read gyro / accelerometer data via SPI.
So far I started adapting the code and info found at:
https://playground.arduino.cc/Main/MPU-6050
I thought it would be fairly easy to use SPI instead of I2C "Wire", and adapt the configuration and registers based on the data sheet, but I realized there's too many possible pitfalls.
Any recommendations?
Gil Sven
  • 167
Z4-
  • 121
For anyone who has not yet figured this out, its very simple.
Basically, for SPI communication with the sensor MPU 6500, its a bit different from what I2C has to offer.
In I2C, basically you will find the data packet is as follows:
(7 bit Slave Address + Read/Write Bit), but in SPI it is as follows:
(Read/Write Bit + 7 Bit Register Address), notice we dont even need the slave address in SPI as the Chip Select is connected from processor(Master) to Sensor(Slave).
So for SPI, lets say you want to write a value 64 to register 0x6B, then: Transmission_data[2]; Transmission_data[0] = 0x6B; Transmission_data[1] = 64;
Lets say you want to read a value from register 0x43, which is GYRO_X_High Byte value, then, Transmission_data[1]; Transmission_data[0] = 0x43 | 0x80; // you need to or it with 0x80(decimal = 128)
Thanks...Hope this helps someone in need of help for SPI as I struggled too in finding this information.
