I had problems with Arduino uno and reseted firmware. Followed this tutorial. Now I can't upload my code Arduino IDE says:
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
I tried loop-back mode, everything is fine.
Firmware was located in this location:
/usr/share/arduino/hardware/arduino/firmwares/atmegaxxu2/Arduino-COMBINED-dfu-usbserial-atmega16u2-Uno-Rev3.hex
Anonymous Penguin
  • 6,365
  • 34
  • 62
There are two processors on the Uno board.
  • The Atmega328P which is the "main" processor with your sketches on it
  • The Atmega16U2 which handles the USB interface
Firmware was located in /usr/share/arduino/hardware/arduino/firmwares/atmegaxxu2/Arduino-COMBINED-dfu-usbserial-atmega16u2-Uno-Rev3.hex
Hopefully you reflashed the Atmega16U2 with that file. Did you?
Therefore the Atmega16U2 is OK. The problem may be with the Atmega328P.
I had problems with Arduino Uno and reseted firmware.
You shouldn't need to do this, I never reflash the firmware on my Atmega16U2.
What problems did you have? Did it involve motors? LEDs? High voltages? Sparks? Flames? Screaming?
Please see the steps described here, run through them, and see if that fixes the problem: Have I bricked my Arduino Uno? Problems with uploading to board
Nick Gammon
  • 38,901
