The problem is a combination of several causes.
Assignments are not atomic
An atomic operation is something that is completely done or not. The opposite is some operation that can be disrupted while executing, leaving thing in a inconsistent state.
This is how the count++ works at machine level in Arduino:
void callback()
count++;
fa: 80 91 0a 02 lds r24, 0x020A
fe: 90 91 0b 02 lds r25, 0x020B
102: a0 91 0c 02 lds r26, 0x020C
106: b0 91 0d 02 lds r27, 0x020D
10a: 01 96 adiw r24, 0x01 ; 1
10c: a1 1d adc r26, r1
10e: b1 1d adc r27, r1
110: 80 93 0a 02 sts 0x020A, r24
114: 90 93 0b 02 sts 0x020B, r25
118: a0 93 0c 02 sts 0x020C, r26
11c: b0 93 0d 02 sts 0x020D, r27
The first four instruction loads the four count bytes into four separate register, the laboriously increment it by one and then store it back in RAM.
Now, toggle is a variable of interest and you want to use it inside loop, like this:
void loop()
uint32_t x = toggle;
And at machine level you get
414: 60 91 04 01 lds r22, 0x0104
418: 70 91 05 01 lds r23, 0x0105
41c: 80 91 06 01 lds r24, 0x0106
420: 90 91 07 01 lds r25, 0x0107
Here we are simply copying the toggle variable into our x variable. As you can see, the copy takes four machine instructions to get completed.
Now, what happens if an interrupt comes while you are copying (or using) toggle?
An interrupt suspend the assignment, go to the ISR (callback in this case and change toggle value. Upon return, copying continues, mixing bytes from the old and new value.
You must use volatile
Any global variable used inside an ISR must be declared volatile. This is an hint to the compiler that the variable could change unexpectedly. Therefore, the volatile variable must be always read afresh, discarding any cached value.
Critical section
The rule for using values changed by ISR is simple:
- Always copy the ISR's global variables to your own temporary variable.
- Before coping, disable interrupts and reenable it after the copy is done. This prevent the ISR from executing while your are copy the values.
Demo
This little demo shows you all of this in action.
The sketch collect all the values from toggle (not disabling interrupts) during one minute and after that print a table showing what it got.
* This sketch show how to deal with variables shared between ISR and main thread.
* By Look Alterno 2018
#include "TimerOne.h"
volatile uint32_t count = 0;
const uint32_t PATTERN_A = 0xFF00FF00;
const uint32_t PATTERN_B = 0x00FF00FF;
volatile uint32_t toggle = PATTERN_A;
#define MAX_CASES 16
struct {
unsigned long value;
int count;
} found[MAX_CASES];
int freeFound = 0;
#define PRINT_INTERVAL 60000L
Serial.begin(9600);
while(!Serial);
Serial.println("");
Serial.println("Test assignment under interrupts");
Serial.println("");
Serial.print("Value A=");
Serial.println(PATTERN_A, HEX);
Serial.print("Value B=");
Serial.println(PATTERN_B, HEX);
Timer1.initialize(500);
Timer1.pwm(9, 512);
Timer1.attachInterrupt(callback);
pinMode(A0, INPUT);
randomSeed(analogRead(A0));
void callback()
count++;
toggle = (count % 2) ? PATTERN_A : PATTERN_B;
void loop()
static unsigned long prev = 0;
// A random delay to simulate some real, variable work being done.
delayMicroseconds(random(250));
// This is the critical section.
// noInterrupts();
// interrupts();
// Now, let's see what value we got.
if(x != PATTERN_A && x != PATTERN_B) {
insert(x);
// Print values found
unsigned long now = millis();
if (now - prev > PRINT_INTERVAL) {
printFound();
prev = now;
* Add a value to a table for counting.
void insert(unsigned long x)
int index = 0;
while(index < freeFound && found[index].value != x) {
index++;
if(index < MAX_CASES) {
if(index == freeFound) {
found[index].value = x;
found[index].count = 1;
freeFound++;
Serial.print(freeFound);
Serial.print(". Add=");
Serial.println(x, HEX);
} else {
found[index].count++;
} else {
Serial.print("*** Table overflow. value=");
Serial.print(x, HEX);
Serial.println(" ***");
* Print the table of found values so far.
void printFound() {
Serial.println("");
Serial.println("Values found");
Serial.println("");
Serial.println("Value - Count");
for (int i=0; i < freeFound; i++) {
Serial.print(found[i].value, HEX); Serial.print(" - "); Serial.println(found[i].count);
If you uncomment noInterrupts and interrupts, every thing works just fine.
Other CPU
More powerful CPUs have atomic assignments, but following this practices makes your code portable across platforms, no matter what. Think of defensive programming
