Using this code to try and play a random song when someone walks by my distance sensor I get an error, the same song (track 0001) plays every time. Any advice?
#include <SoftwareSerial.h>
SoftwareSerial Geno(7, 8); // Rx, Tx
unsigned char Data[10]; unsigned char i;
// defines pins numbers const int trigPin = 8; const int echoPin = 9;
// defines variables long duration; int distance;
void setup() { delay(1000); Geno.begin(9600); delay(1000); SetVolume(30); pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output pinMode(echoPin, INPUT); // Sets the echoPin as an Input Serial.begin(9600); // Starts the serial communication }
void playTrack(int num) { delay(100);
Data[0] = 0x7E;
Data[1] = 0x04;
Data[2] = 0xA0;
Data[3] = 0x00;
Data[4] = 0x00 + num;
Data[5] = 0x7E;
Command(Data,5);
play_pause();
delay(10000);
void SetVolume(int vol) { Data[0] = 0x7E; // START Data[1] = 0x03; // Length Not 0x02 Data[2] = 0xA7; // Command Data[3] = vol; // new volume Data[4] = 0x7E; // END Command(Data,5); }
void play_pause() { Data[0] = 0x7E; // START Data[1] = 0x02; // Length Data[2] = 0xA3; // Command Data[3] = 0x7E; // Mode parameter Command(Data,4); }
void Command(unsigned char *Data, int length) { for (int i=0; i<length; i++) { Geno.write(Data[i]); } }
void loop() { //Assigns a random number int song = random(0,200); Serial.print("Song is:"); Serial.print(song); Serial.print("\n"); // Clears the trigPin digitalWrite(trigPin, LOW); delayMicroseconds(2);
// Sets the trigPin on HIGH state for 10 micro seconds digitalWrite(trigPin, HIGH); delayMicroseconds(10); digitalWrite(trigPin, LOW);
// Reads the echoPin, returns the sound wave travel time in microseconds duration = pulseIn(echoPin, HIGH);
// Calculating the distance distance = duration * 0.034 / 2;
Serial.print("Distance: "); Serial.println(distance); if (distance < 20) { playTrack(random(1,25)); } //playTrack(1); //playTrack(2); }
ocrdu
  • 1,795
Pagaley 12
Disclaimer: I know nothing about this media player except what's in this question. I'd never heard of it before. The following is simply from observation of the code you posted.
Look at your play_pause() function where the meanings of all the elements are described.
Data[3] = 0x7E;          //Mode parameter
Command(Data,4);
It seems a message starts with 0x7E, followed by the length , followed by a command and whatever else, followed by another 0x7E.
The length field is 1 less than the total length, so I guess it doesn't include the 'start', or whatever - there are various equivalent ways you could look at it.
In playTrack() you set 6 elements, but with the length element set to 4. You then tell Command() there are 5. So the last element (0x7E) won't get sent, and the length element which you have sent is wrong anyway.
The receiver is going to get into some weird state, I presume. Perhaps that explains the problem you're seeing.
Mark Smith
  • 2,181
random(1,25) is deterministic. It's PRNG should produce the same sequence of outputs in the same order each time. You need to call randomSeed() at some point, passing it an unpredictable value. Something like:
if(distance < 20){
  randomSeed(micros());
dandavis
  • 1,037
