I am trying to send the temperatures from an DS18B20 to ThingSpeak, using an ESP8266. You can see the code I am using for that.
When I run the code I do not get any errors. In serial monitor it just shows that it is not connected to WiFi. If I change the WiFi name in code to something not even existing I still do not get any errors. I do not think that the ESP even finds the WiFi.
I think that the only problem to get everything work is just to get the WiFi connection to work properly. I have also checked the ESP with another simple code just to check that it is not broken and it actually get the code from my computer.
Here is the code I am using. (I have removed my password etc... )
//nodeMCU v1.0 (black) with Arduino IDE
//stream temperature data DS18B20 with 1wire on ESP8266 ESP12-E (nodeMCU v1.0)
//shin-ajaran.blogspot.com
//nodemcu pinout https://github.com/esp8266/Arduino/issues/584
#include <ESP8266WiFi.h>
#include <DallasTemperature.h>
#include <OneWire.h>
//Def
#define myPeriodic 15 //in sec | Thingspeak pub is 15sec
#define ONE_WIRE_BUS D4  // DS18B20 on arduino pin2 corresponds to D4 on physical board
//#define mySSR 0  // Solid State Relay on pin 0
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature DS18B20(&oneWire);
float prevTemp = 0;
const char* server = "api.thingspeak.com";
String apiKey ="******";
const char* MY_SSID = "******";
const char* MY_PWD = "******";
int sent = 0;
    Serial.begin(115200);
    connectWifi();
    float temp;
    //char buffer[10];
    //DS18B20.requestTemperatures();
    //temp = DS18B20.getTempCByIndex(0);
    temp=1111;
    //String tempC = dtostrf(temp, 4, 1, buffer);//handled in sendTemp()
    Serial.print(String(sent)+" Temperature: ");
    Serial.println(temp);
    //if (temp != prevTemp)
    //  sendTeperatureTS(temp);
    //  prevTemp = temp;
    int count = myPeriodic;
    while(count--)
    delay(1000);
void connectWifi()
    Serial.print("Connecting to "+*MY_SSID);
    WiFi.begin(MY_SSID, MY_PWD);
        delay(1000);
        Serial.print(".");
    Serial.println("");
    Serial.println("Connected");
    Serial.println("");
}//end connect
void sendTeperatureTS(float temp)
    WiFiClient client;
    if (client.connect(server, 80)) { // use ip 184.106.153.149 or api.thingspeak.com
        Serial.println("WiFi Client connected ");
        String postStr = apiKey;
        postStr += "&field1=";
        postStr += String(temp);
        postStr += "\r\n\r\n";
        client.print("POST /update HTTP/1.1\n");
        client.print("Host: api.thingspeak.com\n");
        client.print("Connection: close\n");
        client.print("X-THINGSPEAKAPIKEY: " + apiKey + "\n");
        client.print("Content-Type: application/x-www-form-urlencoded\n");
        client.print("Content-Length: ");
        client.print(postStr.length());
        client.print("\n\n");
        client.print(postStr);
        delay(1000);
    }//end if
    sent++;
    client.stop();
}//end send
gre_gor
  • 1,682
  • 28
Ali Karim
Maybe you have a space in your WIFI SSID so you should check this in your router. Also maybe your WIFI is on 5Ghz and the ESP can't see it because it is only for 2.4 Ghz. Also if your WIFI AP is on a channel from 13 - 14 it also couldn't be seen by the ESP. And to test your ESP you can run the scan example and if it works you should try the web server example to connect to your network. If that all will work ok than the problem is in your code.
Coder_fox
  • 686
I had the same problem, when i tried to connect to my home wifi i got stuck with just printing dots and never could connected. First of all i though that my ssid or password had a typo, but it hadn't. Then i changed the nodemcu and the problem persisted. But when i tried to connect to other wifi it worked. So the problem was in my modem/router.So i changed my modem/router configuration to: Operation mode: 802.11g+n to Automatic Channel: 11 to Automatic Channel Bandwich: 20 to Automatic
then the problem was solved.
In order to connect to Wifi from ESP32 and other boards, the WiFi connection needs to be 2.4GHz, wireless mode must be legacy. It cannot be set to Auto or N only. Go to your router box web page, and change this setting under Advanced Settings > Wireless.
The only code required to connect is.
void loop() { while (WiFi.status() != WL_CONNECTED) { delay(1000); Serial.print("."); } ... }
minimalpop
  • 103
Try to add WiFi.hostname("ESP-host"); before WiFi.begin(ssid, password); - it works in my case.
gbg
  • 518
