I want to create an integer whose total value cannot go beyond a range of numbers when added to and subtracted from. For example, if the "total_value" started at 0 (of a total possible range between -5 and 5), and then, using a button that added 1 to the total value, I got to 5, if I was to press it again it would not go to six but either reset to 5 or block another input of +1.
How would I go about achieving something to this effect?
Liam
Liam
  • 167
You are probably looking for the constrain() macro (an existing implantation of clamp logic, credit goes to @Edgar Bonet)
value = constrain(value + input, -5, 5);
If you get tired of writing constrain() you can even wrap it in a new type (which might be over-engeneering), producing something like following(code not tested)
template<typename T>
struct BoundValue {
    T value;
    const T vmin, vmax;
    //similar for other operators +,/,-=,...
    decltype(*this)& operator+=(T operand) { value = constrain(value + operand, vmin, vmax); return *this; }
    operator T() const { return value; }
    BoundValue(const T& vmin, const T& vmax) : vmin(vmin), vmax(vmax) {}
    BoundValue& operator=(const T& other) { value = constrain(other, vmin, vmax); return *this; }
and use like variable of its argument type
BoundValue<int> val(-5, 5);
val += 6;//val = 5
wondra
  • 158
For adding:
total_value = total_value + 1;
if (total_value > 5)
  total_value = 5;
And for subtracting:
total_value = total_value - 1;
if (total_value < -5)
  total_value = -5;
You may find a C or C++ tutorial very helpful.
Another method for adding:
if (total_value < 5)
  total_value++;
if (total_value > -5)
  total_value--;
Nick Gammon
  • 38,901
You can not create a number with arbitrary upper and lower limits. It is common in the C language to create an integer comprised of 16 bits. Such an integer has a minimum of:
-(2^15) = -32768
...and maximum of:
(2^15) - 1 = +32767
Instead, after pressing the positive button, consider testing if "total_value" is 5 and skipping adding 1 to "total_value" if TRUE. Conversely, after pressing the negative button, consider testing if "total_value" is -5 and skipping subtracting 1 from "total_value" if TRUE.
Edgar Bonet
  • 45,094
  • 81
st2000
  • 7,513
