I have experimented with my NodeMCU (ESP8266-12F, but the core chip is the same ESP8266EX).
First, the theory: UART is a asynchronous serial protocol. It has a configuration which consits of the baud rate (bits per second), parity bit (enabled or not) and number of stop bits (between 1-2). A common configuration is "9600N1", meaning 9600 bits per second, no parity bit, 1 stop bit.
If you want to trasmit the bitstring 0101 0101 with no parity, 1 stop bit, the RX line voltage will be:
RX line idles in high state (for us: 3.3V). Transmission is started by the start bit, which means that the line is pulled LOW. Then, the bits are transmitted LSB to MSB, followed by parity (if enable) and the stop bits.
I wrote the sketch
#include <Arduino.h>
//use 300 Baud, lol
Serial.begin(300);
if(Serial.available()) {
char readChar = (char) Serial.read();
Serial.println("Read char: " + String(readChar) + " hex " + String((int)readChar, HEX));
When transmitting a normal "A" (binary: 0100 0001) over serial, it looks like this in a logic analyzer:
When I connected a pulled-up button the RX line and press, the signal goes as
As one can see, the analyzer sees the pushing down of the button as a start bit, but the timing is way of. The line is pulled back to high much later. The time slot for the stop bit (which must be 1) was missed, so the logic analyzer displays "FRAMING ERROR". But the UART circuit inside the ESP8266 doesn't seem to care. It reads this as the transmission of a byte of the value "0x00".
Serial output: Read char: hex 0
So, in response to the question "what would happen the push button was pressed?" we can say: At this speed of 300 baud (lowest possible setting), the UART received a bogus transmission but still reads it as an incomming 0x00 byte. However, depending on the bouncing of the signal due to the button presses, other received byte values might well be possible. You could be able to de-bounce the button to make the signal more stable, timing wise.
Anyway, you should not make a push button act as a crude UART transmitter if it isn't the absolute last possible solution. Depending on your application, you might be able to use the solution from this question and switch the function of the TXD0 and RXD0 to GPIO (more info). If you know exactly when to expect a button push, switch the pins to GPIO mode before and poll the status of the button (or install an interrupt).
However, as a bottom line: If you have no idea when the button will be pushed, then you will be fundamentally unable to distinguish the cause of the RX line falling low at the time the transition happens. It could be the transmission of some actual data (maybe also the zero-byte), but it could have also been the button.
A I²C GPIO port expander like the MCP23017 (link) would make much more sense, especially if you already have an I2C bus. There are also SPI devices available for this.
