I need to monitor a battery plugged to an ATmega running on standalone mode.
I use the "ATmega on a breadboard (8 MHz internal clock)" bootloader. More info here
When the ATmega is powered with 5V the sketch outputs good values : arround 5100 mV.
But when I power it with 3.3V the sketch gives strange values : arround 178619 mV.
Here is my code Inspired from here
void setup()
Serial.begin(9600);
Serial.println(F("Internal Voltage Sensor"));
void loop()
Serial.println( readVcc());
delay(1000);
long readVcc()
long voltage=0;
uint8_t wADC;
// Read 1.1V reference against AVcc
// set the reference to Vcc and the measurement to the internal 1.1V reference
ADMUX = _BV(REFS0) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
ADCSRA |= _BV(ADEN); // enable the ADC
delay(20); // Wait for Vref to settle
ADCSRA |= _BV(ADSC); // Start conversion
while (bit_is_set(ADCSRA,ADSC)); // measuring
// Reading register "ADCW" takes care of how to read ADCL first and ADCH then.
wADC = ADCW;
voltage = 11253000L / wADC; // Calculate Vcc (in mV); 1125.3 = 1.1*1023*1000
return voltage; // Vcc in millivolts
I don't understand what's going on. The returned value with Vcc=3.3V should be lower than with VCC=5V. Something like 3300 mV !
