I'm trying to write two strings to an Arduino Uno's EEPROM. Here, the first code block works fine: it writes string(True/False) at 'address 0'. But the second block, which writes data at 'address 5', is not working as expected.Reading data at address 5 prints a blank line. What am I missing here? Is this the correct way to write two different strings to EEPROM?
First code block:
int state = LOW;
char first_eeprom_value;
if (state == LOW) {
state = HIGH;
char example_string[4] = "True";
first_eeprom_value = EEPROM.read(0);
Serial.println(first_eeprom_value);
for (int i = 0 ; i < 5 ; i++) {
EEPROM.update(i, example_string[i]);
} else {
state = LOW;
char example_string[5] = "False";
for (int i = 0 ; i < 5; i++) {
Time = millis();
Second code block:
char first_eeprom_value1;
if (state1 == LOW) {
state1 = HIGH;
char example_string1[4] = "True";
first_eeprom_value1 = EEPROM.read(5);
Serial.println(first_eeprom_value1);
for (int i = 5 ; i < 11 ; i++) {
EEPROM.update(i, example_string1[i]);
} else {
state1 = LOW;
char example_string1[5] = "False";
Time = millis();
//reading data at address 5
int addr = 5;
char value = EEPROM.read(addr);
Serial.println(value);// this prints blank line
