9
I am using Arduino UNO and has kept in SLEEP_MODE_PWR_DOWN mode & want it to wakeup using MPU6050 hardware INT pin (which should send a signal when MPU is in motion). I have used the article https://lukelectro.wordpress.com/2016/08/11/how-to-enable-motion-detection-interrupt-on-mpu6050/
    #include <Wire.h>
    //Analog port 4 (A4) = SDA (serial data)
    //Analog port 5 (A5) = SCL (serial clock)
    #define SIGNAL_PATH_RESET  0x68
    #define I2C_SLV0_ADDR      0x37
    #define ACCEL_CONFIG       0x1C
    #define MOT_THR            0x1F  // Motion detection threshold bits [7:0]
    #define MOT_DUR            0x20  // Duration counter threshold for motion interrupt generation, 1 kHz rate, LSB = 1 ms
    #define MOT_DETECT_CTRL    0x69
    #define INT_ENABLE         0x38
    #define WHO_AM_I_MPU6050   0x75 // Should return 0x68
    #define INT_STATUS 0x3A
    //when nothing connected to AD0 than address is 0x68
    #define ADO 0
    #if ADO
    #define MPU6050_ADDRESS 0x69  // Device address when ADO = 1
    #else
    #define MPU6050_ADDRESS 0x68  // Device address when ADO = 0
    #endif
    /*    Example for using write byte
          Configure the accelerometer for self-test
          writeByte(MPU6050_ADDRESS, ACCEL_CONFIG, 0xF0); // Enable self test on all three axes and set accelerometer range to +/- 8 g */
    void writeByte(uint8_t address, uint8_t subAddress, uint8_t data)
      Wire.begin();
      Wire.beginTransmission(address);  // Initialize the Tx buffer
      Wire.write(subAddress);           // Put slave register address in Tx buffer
      Wire.write(data);                 // Put data in Tx buffer
      Wire.endTransmission();           // Send the Tx buffer
    //  Serial.println("mnnj");
    //example showing using readbytev   ----    readByte(MPU6050_ADDRESS, GYRO_CONFIG);
    uint8
_t readByte(uint8_t address, uint8_t subAddress)
  uint8_t data;                            // `data` will store the register data
  Wire.endTransmission(false);             // Send the Tx buffer, but send a restart to keep connection alive
  Wire.requestFrom(address, (uint8_t) 1);  // Read one byte from slave register address
  data = Wire.read();                      // Fill Rx buffer with result
  return data;                             // Return data read from slave register
void setup()
    * #define SIGNAL_PATH_RESET  0x68
      #define INT_STATUS 0x3A*/
    Serial.begin(9600);
    writeByte( MPU6050_ADDRESS, SIGNAL_PATH_RESET, 0x07);//Reset all internal signal paths in the MPU-6050 by writing 0x07 to register 0x68;
    writeByte( MPU6050_ADDRESS, I2C_SLV0_ADDR, 0x20);//write register 0x37 to select how to use the interrupt pin. For an active high, push-pull signal that stays until register (decimal) 58 is read, write 0x20.
    writeByte( MPU6050_ADDRESS, ACCEL_CONFIG, 0x01);//Write register 28 (==0x1C) to set the Digital High Pass Filter, bits 3:0. For example set it to 0x01 for 5Hz. (These 3 bits are grey in the data sheet, but they are used! Leaving them 0 means the filter always outputs 0.)
    writeByte( MPU6050_ADDRESS, MOT_THR, 0x14);  //Write the desired Motion threshold to register 0x1F (For example, write decimal 20).
    writeByte( MPU6050_ADDRESS, MOT_DUR, 0x01 );  //Set motion detect duration to 1  ms; LSB is 1 ms @ 1 kHz rate
    writeByte( MPU6050_ADDRESS, MOT_DETECT_CTRL, 0x15); //to register 0x69, write the motion detection decrement and a few other settings (for example write 0x15 to set both free-fall and motion decrements to 1 and accelerometer start-up delay to 5ms total by adding 1ms. )
    writeByte( MPU6050_ADDRESS, INT_ENABLE, 0x40 ); //write register 0x38, bit 6 (0x40), to enable motion detection interrupt.     */
    pinMode(13, OUTPUT);      // sets the digital LED pin 13 as output
    pinMode(7, INPUT);        // sets the digital pin 7 as input
    uint16_t readdata;
void loop()
      Serial.println("scdf");
      if(digitalRead(7)==1)
        while(1)
          digitalWrite(13, 1);
          delay(100);
  //    readdata = readByte(MPU6050_ADDRESS,WHO_AM_I_MPU6050);
  //    Serial.println(readdata);
Gerben
  • 11,332
  • 22
  • 34
bandejiya
  • 317
Well, this code worked. In this code, MPU's INT PIN is Active Low so generates Ground on motion which is than connected to INT0 or arduino UNO pin 2 which generates interrupt and wakes UP the MCU
#include <avr/sleep.h>
#include <Wire.h> //Analog port 4 (A4) = SDA (serial data) //Analog port 5 (A5) = SCL (serial clock) #define SIGNAL_PATH_RESET 0x68 #define I2C_SLV0_ADDR 0x37 #define ACCEL_CONFIG 0x1C #define MOT_THR 0x1F // Motion detection threshold bits [7:0] #define MOT_DUR 0x20 // Duration counter threshold for motion interrupt generation, 1 kHz rate, LSB = 1 ms #define MOT_DETECT_CTRL 0x69 #define INT_ENABLE 0x38 #define WHO_AM_I_MPU6050 0x75 // Should return 0x68 #define INT_STATUS 0x3A //when nothing connected to AD0 than address is 0x68 #define ADO 0 #if ADO #define MPU6050_ADDRESS 0x69 // Device address when ADO = 1 #else #define MPU6050_ADDRESS 0x68 // Device address when ADO = 0 #endif
int wakePin = 2; // pin used for waking up
int led = 13; int flag = 0;
void wakeUpNow() { // THE PROGRAM CONTINUES FROM HERE AFTER WAKING UP (i.e. after getting interrupt) // execute code here after wake-up before returning to the loop() function
// timers and code using timers (serial.print and more...) will not work here.
// we don't really need to execute any special functions here, since we
// just want the thing to wake up
delay(500); Serial.println("WOKEN UP !!!!!!!!!!"); delay(500); int count = 10; while (count != 0) { delay(1000); count--; Serial.println(count); delay(1000); } // precautionary while we do other stuff detachInterrupt(0);
/* Example for using write byte Configure the accelerometer for self-test writeByte(MPU6050_ADDRESS, ACCEL_CONFIG, 0xF0); // Enable self test on all three axes and set accelerometer range to +/- 8 g */ void writeByte(uint8_t address, uint8_t subAddress, uint8_t data) { Wire.begin(); Wire.beginTransmission(address); // Initialize the Tx buffer Wire.write(subAddress); // Put slave register address in Tx buffer Wire.write(data); // Put data in Tx buffer Wire.endTransmission(); // Send the Tx buffer // Serial.println("mnnj");
//example showing using readbytev ---- readByte(MPU6050_ADDRESS, GYRO_CONFIG); uint8_t readByte(uint8_t address, uint8_t subAddress) { uint8_t data; // data will store the register data
Wire.beginTransmission(address); // Initialize the Tx buffer Wire.write(subAddress); // Put slave register address in Tx buffer Wire.endTransmission(false); // Send the Tx buffer, but send a restart to keep connection alive Wire.requestFrom(address, (uint8_t) 1); // Read one byte from slave register address data = Wire.read(); // Fill Rx buffer with result return data; // Return data read from slave register }
  • #define SIGNAL_PATH_RESET 0x68 #define I2C_SLV0_ADDR 0x37 #define ACCEL_CONFIG 0x1C #define MOT_THR 0x1F // Motion detection threshold bits [7:0] #define MOT_DUR 0x20 // Duration counter threshold for motion interrupt generation, 1 kHz rate, LSB = 1 ms #define MOT_DETECT_CTRL 0x69 #define INT_ENABLE 0x38 #define WHO_AM_I_MPU6050 0x75 // Should return 0x68 #define INT_STATUS 0x3A*/
Serial.begin(9600); writeByte(MPU6050_ADDRESS, 0x6B, 0x00); writeByte(MPU6050_ADDRESS, SIGNAL_PATH_RESET, 0x07); //Reset all internal signal paths in the MPU-6050 by writing 0x07 to register 0x68; writeByte(MPU6050_ADDRESS, I2C_SLV0_ADDR, 0x20); //write register 0x37 to select how to use the interrupt pin. For an active high, push-pull signal that stays until register (decimal) 58 is read, write 0x20. writeByte(MPU6050_ADDRESS, ACCEL_CONFIG, 0x01); //Write register 28 (==0x1C) to set the Digital High Pass Filter, bits 3:0. For example set it to 0x01 for 5Hz. (These 3 bits are grey in the data sheet, but they are used! Leaving them 0 means the filter always outputs 0.) writeByte(MPU6050_ADDRESS, MOT_THR, 10); //Write the desired Motion threshold to register 0x1F (For example, write decimal 20).
writeByte(MPU6050_ADDRESS, MOT_DUR, 40); //Set motion detect duration to 1 ms; LSB is 1 ms @ 1 kHz rate
writeByte(MPU6050_ADDRESS, MOT_DETECT_CTRL, 0x15); //to register 0x69, write the motion detection decrement and a few other settings (for example write 0x15 to set both free-fall and motion decrements to 1 and accelerometer start-up delay to 5ms total by adding 1ms. )
writeByte(MPU6050_ADDRESS, INT_ENABLE, 0x40); //write register 0x38, bit 6 (0x40), to enable motion detection interrupt.
writeByte(MPU6050_ADDRESS, 0x37, 160); // now INT pin is active low
pinMode(2, INPUT); // sets the digital pin 7 as input
pinMode(wakePin, INPUT_PULLUP); // wakePin is pin no. 2 pinMode(led, OUTPUT); // led is pin no. 13 // attachInterrupt(0, wakeUpNow, LOW); // use interrupt 0 (pin 2) and run function wakeUpNow when pin 2 gets LOW
void sleepNow() { set_sleep_mode(SLEEP_MODE_PWR_DOWN); // sleep mode is set here
sleep_enable(); // enables the sleep bit in the mcucr register
delay(500); Serial.println("About to sleep"); delay(500); attachInterrupt(0, wakeUpNow, LOW); // use interrupt 0 (pin 2) and run function
delay(500); Serial.println("Interupt attached"); delay(500); sleep_mode(); // here the device is actually put to sleep...!!
// THE PROGRAM CONTINUES FROM HERE AFTER INTERRUPT IS CLOSED delay(500); Serial.println("Continuing main program after interupt"); delay(500);
sleep_disable(); // first thing after waking from sleep: disable sl¯eep...
delay(500); Serial.println("Sleep disabled"); delay(500); } uint16_t readdata; void loop() { if (digitalRead(2) == 0) { {
  delay(100);
  digitalWrite(13, 0);
  delay(100);
} sleepNow(); // sleep function called here readdata = readByte(MPU6050_ADDRESS, 0x3A); Serial.print(readdata); Serial.print(","); readdata = readByte(MPU6050_ADDRESS, 0x37); Serial.println(readdata);
bandejiya
  • 317
