30
Is it possible to build a HID device (like a keyboard) using an Arduino uno?
At the time being, I have button inputs on the Arduino giving outputs on the serial line. So, how can I transform my current firmware into something that can behave like a HID keyboard?
  • Shall I write a new window device driver?
  • Shall I create a software layer that could take my serial data and have windows read it as HID input?
  • Is there any better way to achieve this, if it is possible at all?
zmo
  • 1,518
Stuyvenstein
  • 435
yes it is! And there's a great tutorial on how to do that over here
As the tutorial shows you, you need to transform your firmware code so instead of printing the events, you actually trigger events. What you need to do, is add to your code:
void triggerKey(uint8_t mod, uint8_t chr) {
    uint8_t buf[8] = {mod, chr, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
    // press key
    Serial.write(buf, 8);
    // emulate key press delay
    delay(10);
    buf[1] = 0x00;
    // release key
What you're doing here, is send from your main Arduino microcontroller events over the serial line to the smaller microcontroller that handles USB communication. That microcontroller will take those key "buffers" and transfer them as USB HID Keyboard key presses over USB.
Beware that the key character (chr in the code here), is actually a keycode sent over USB that gets interpreted by your USB HID driver, which then translates it into a real character using the current layout you've setup for your keyboard.
The mod character is one of the modifier keys you have on the keyboard (shift, control, alt...), 0x00 being no modifier.
No, you don't need! With the DFU upgrade, your arduino will be seen as a USB keyboard by windows.
You neither need to do that, and it's actually a very bad idea for many reasons:
  • your solution would not be portable, and thus you'd need to hack something for every platform you may use,
  • your solution would imply a lot of new code ; the more code one write, the more bugs is likely to be in your system,
  • your solution would be really hackish, as it would behave as a device driver (i.e. kernel land) taking input from a user program (i.e. user land) and is likely to not work, be a hell to debug, and prone for security issues... If that's even possible to do!
I'm using an Uno, but I'll look at what you posted because last time we considered the DFU update but we're kinda scared of bricking stuff
Finally you're having concerns, in a comment, about bricking your arduino. Please believe me and the author of the article that you cannot brick your arduino doing a firmware flash:
NOTE: There is no chance of ‘bricking’ the device using this method. The Arduino bootloader firmware can always be updated using the DFU protocol!
In case something gets really badly wrong, and you get a bootloader corruption in the little AVR (atmega8u2), you still can reflash it using another arduino or an atmel programmer using the 6 pins next to the USB plug.
In the end, know that the only way to brick an AVR, thus an Arduino as well, is to play with the fuses and reset the programming fuses. And even then, you may use HVSP to save your device, though it's often less trouble to just take a new chip.
Glorfindel
  • 578
zmo
  • 1,518
I created a project that fully replaces the Arduino Bootloader. You are able to upload sketches and use it as HID. See Project HID on Github: https://github.com/NicoHood/HID
