Method summary
(section added on 2018-01-28)
There are several methods available for timing code. I am adding this
preliminary section to my answer in order to provide comparative data on
several methods. The methods covered in the table below are those
proposed as answers to both this question and a duplicate question of
this. As this question has been tagged “arduino-uno”, all
this data assumes an AVR-based board clocked at 16 MHz.
Method comparison:
| method | resolution | max. time | typ. overhead |
| `millis()` | 1 – 2 ms | 49.7 days | 0.69 – 1.3 µs |
| `micros()` | 4 µs | 71.6 min | 2.8 – 2.9 µs |
| Timer 1 | 0.0625 µs | 4.096 ms | 0.25 – 0.5 µs |
| pin toggling | scope-limited | ∞ | 0.125 µs |
| cycle counting | 0.0625 µs | boredom-limited | 0 |
| looping | N.A. | N.A. | 0.25 µs |
The methods are characterized by the following criteria:
- Resolution is the granularity of the measurement, the smaller the
better.
- Maximum measurable time: any method that does timing arithmetics
on the Arduino is prone to overflows if measuring too long times. Note
that a timer rolling over to zero during the measurement is not a
problem, as long as the period being measured is less than
the rollover period.
- Typical measurement overhead: the code used to measure the timings
takes itself a finite time to execute, thus one ends up measuring the
execution time of the “instrumented” code, which is slightly larger
than the time taken by the code one is trying to profile. This
overhead should in principle be subtracted from the result, but it is
often not known exactly, as it depends on how the compiler optimizes
both the instrumented and the non-instrumented code.
The methods listed in the table are:
millis(), which may be the most obvious choice, as it is so well
known. Its low resolution, however, makes it ill-suited for timing
code execution. It should be noted that the millis() counter is
incremented every 1024 µs. Most of the time it is incremented by
1 but, every 43 ms (roughly) it is incremented by 2 in order to
avoid creeping drift. This is why its resolution is stated as
“1 – 2 ms” in the table.
micros(), as proposed in ratchet freak's answer, is usually
a good choice, the main caveat being the 4 µs resolution, when
one could naively expect 1 µs. It also has a significant
overhead.
- Timer 1, which is discussed in the second part of this answer, is
my favorite: it has single cycle resolution and low overhead. However,
it is incompatible with other uses of the timer (PWM, Servo
library...). It is also limited to measuring small delays.
- Pin toggling, as proposed by 4ilo, and by myself in the third
part of this answer, is ideal if you have an oscilloscope handy. Any
half-decent scope should provide single-cycle resolution. It is also
minimally invasive on the code being measured and has minimal
overhead.
- Cycle counting, as proposed in Majenko's answer, is arguably
the “perfect” method: it is cycle-accurate, does not modify the code
and has zero overhead. However, for anything beyond a handful
instructions, it quickly becomes tedious. And it requires some
understanding of the AVR assembly.
- Looping, as proposed in Michel Keijzers' answer, is not a
measurement technique per se. It is meant to be used in conjunction
with another technique in order to improve the resolution and dilute
the overhead. However, lopping carries it's own overhead, which is
typically 4 CPU cycles per iteration, assuming a 16-bit loop
counter.
Using Timer 1
(original answer of 2017-10-23)
One technique I often use is to make Timer 1 count at the full CPU speed
and use it to time the code I want to profile. For example:
volatile uint8_t pin = 2;
volatile uint8_t value = HIGH;
void setup()
Serial.begin(9600);
// Set Timer 1 to normal mode at F_CPU.
TCCR1A = 0;
TCCR1B = 1;
// Time digitalWrite().
cli();
uint16_t start = TCNT1;
digitalWrite(pin, value);
uint16_t finish = TCNT1;
sei();
uint16_t overhead = 8;
uint16_t cycles = finish - start - overhead;
Serial.print("digitalWrite() took ");
Serial.print(cycles);
Serial.println(" CPU cycles.");
void loop(){}
Note the volatile variables used to prevent the compiler from
optimizing them as constants.
Note also that when you profile some code you are inevitably slowing it
down, because of the time taken by the profiling operations themselves.
This is what the overhead variable above accounts for. In order to
know the exact overhead, I start with a guess, compile and disassemble,
and then count the number of clock cycles spent in profiling that will
be counted by the timer. Then I adjust the overhead value, compile and
disassemble again, and make sure the overhead has not changed. This is
also when you have to ask yourself what exactly you want to count. Here
I am counting the time needed to execute call digitalWrite, but not
the time needed to get the arguments in the proper registers, as I am
artificially slowing this down by making them volatile.
This method is good for anything that takes more than roughly a dozen,
and less that 65,536 clock cycles. Less than that, clock counting would
be simpler, since you still have to clock-count the overhead. More than
that, the count would overflow, and you could instead just use
micros(), and live with its inherent inaccuracy.
Toggling a pin
(section added on 2017-10-23)
If you have a scope, there is another method that is minimally
invasive on your code: toggle a pin just before and just after the thing
you want to time. E.g., assuming you have previously
pinMode(13, OUTPUT):
// Set pin 13 HIGH.
PORTB |= _BV(PB5);
// The thing we want to time.
// Set pin 13 LOW.
PORTB &= ~_BV(PB5);
This will create a pulse that you can measure on the scope. Note that
using direct port access, like here, the overhead is only two CPU cycles,
or 125 ns. Also, direct port access won't use any CPU register, so
chances are the compiler will not generate less efficient code than when
not including the timing part.
