I am simply trying to send a simple HTTP request from an Arduino Uno with w5500 Ethernet Shield to a local server running on my PC.
The two are connected via a crossover ethernet cable and I am able to host a server on the Arduino that is accessible from my PC browser. Now I am trying to use the PC as a server and the Arduino as the client.
Using the simple WebClient example, I can send a successful GET request to google.com from the Arduino.
Here is what I am trying that is failing:
1 - Start a local server via running http-server in my command prompt. That successfully starts a server at 192.168.56.1:8080 that I can access via my browser
2 - Change the Web Client example to use
IPAddress server(192,168,56,1);
and change the port to
if (client.connect(server, 8080))
3 - Run this Arduino sketch. The connection fails and I don't know why. I have allowed port 8080 full input access through the Windows firewall.
Any ideas?
nmarie22
The answer was simple. Instead of trying to connect to the IP address of the local server (192.168.56.1) I had to use the IP address of the ethernet connection between the Arduino and the PC (found using the ipconfig command on the command prompt).
nmarie22
