9
I have got some difficulties understanding the memory management.
Arduino documentation says, it is possible to keep constants like strings or whatever I don't want to change during runtime in program memory. I think of it as embedded somewhere in the code segment, which must be fairly possible inside a von-Neumann-architecture. I want to make use from that to make my UI menu on a LCD possible.
But I'm bewildered by those instructions to just read and print data from program memory:
strcpy_P(buffer, (char*)pgm_read_word(&(string_table[i]))); // Necessary casts and dereferencing, just copy.
    Serial.println( buffer );
Why on earth do I have to copy the damn content to RAM before accessing it? And if this is true, what happens to all the code then? Is it also loaded to RAM before execution? How is the code (32kiB) handled then with only 2kiB RAM? Where are those little goblins carrying floppy disks?
And even more interesting: What happens to literal constants like in this expression:
a = 5*(10+7)
are 5, 10 and 7 really copied to RAM before loading them into registers? I just can't believe that.
Ariser
  • 577
  • 26
AVR is a modified Harvard architecture family, so code is stored in flash only, whereas data exists primarily in RAM when being manipulated.
With that in mind, let's address your questions.
You don't need to per se, but by default code assumes that data is in RAM unless the code is modified to specifically look in flash for it (such as with strcpy_P()).
Nope. Harvard architecture. See the Wikipedia page for the full details.
The preamble generated by the compiler copies the data that should be modifiable/modified into SRAM before running the actual program.
Dunno. But if you happen to see them then there's nothing I can do to help.
... are 5, 10 and 7 really copied to RAM before loading them into registers?
Nah. The compiler evaluates the expression at compile time. Whatever else happens depends on the lines of code around it.
Ignacio Vazquez-Abrams
  • 17,733
  • 28
This is how Print::print prints from program memory in the Arduino library:
size_t Print::print(const __FlashStringHelper *ifsh)
  const char PROGMEM *p = (const char PROGMEM *)ifsh;
  size_t n = 0;
  while (1) {
    unsigned char c = pgm_read_byte(p++);
    if (c == 0) break;
    n += write(c);
  return n;
__FlashStringHelper* is an empty class that allows for overloaded functions like print to differentiate a pointer to program memory from one to normal memory, as both are seen as const char* by the compiler (see https://stackoverflow.com/questions/16597437/arduino-f-what-does-it-actually-do)
So you could overload the print function for your LCD display so that it takes a __FlashStringHelper* argument, lets call it LCD::print, and then use lcd.print(F("this is a string in progmem"));' to call it.F()` is a macro that ensures the string is in program memory.
To predefine the string (to be compatible with built-in Arduino print) I have used:
const char firmware_version_s[] PROGMEM = {"1.0.2"};
__FlashStringHelper* firmware_version = (__FlashStringHelper*) firmware_version_s;
Serial.println(firmware_version);
I think an alternative would be something like
size_t LCD::print_from_flash(const char *pgms)
  const char PROGMEM *p = (const char PROGMEM *) pgms;
  size_t n = 0;
  while (1) {
    if (c == 0) break;
    n += write(c);
  return n;
which would avoid the __FlashStringHelper cast.
geometrikal
  • 2,925
All constants are initially in program memory. Where else would they be when the power is off?
It's actually Harvard architecture.
You don't. In fact there is a hardware instruction (LPM - Load Program Memory) which moves data directly from program memory into a register.
I have an example of this technique in Arduino Uno output to VGA monitor. In that code there is a bitmapped font stored in program memory. It is read from that on-the-fly and copied to the output like this:
  // blit pixel data to screen
  while (i--)
    UDR0 = pgm_read_byte (linePtr + (* messagePtr++));
A disassembly of those lines shows (in part):
  f1a:  e4 91           lpm r30, Z+
  f1c:  e0 93 c6 00     sts 0x00C6, r30
You can see that a byte of program memory was copied into R30, and then immediately stored into the USART register UDR0. No RAM involved.
However there is a complexity. For normal strings the compiler expects to find data in RAM not PROGMEM. They are different address spaces, and therefore 0x200 in RAM is something different from 0x200 in PROGMEM. Thus the compiler goes to the trouble of copying constants (like strings) into RAM at program startup, so it doesn't have to worry about knowing the difference later on.
Good question. You won't get away with having more than 2 KB of constant strings, because there won't be room to copy them all.
That's why people who are writing things like menus and other wordy stuff, take extra steps to give the strings the PROGMEM attribute, which disables them being copied into RAM.
If you add the PROGMEM attribute you have to take steps to let the compiler know that these strings are in a different address space. Making a complete (temporary) copy is one way. Or just print directly from PROGMEM, a byte at a time. An example of that is:
// Print a string from Program Memory directly to save RAM
void printProgStr (const char * str)
  char c;
  if (!str)
    return;
  while ((c = pgm_read_byte(str++)))
    Serial.print (c);
} // end of printProgStr
If you pass this function a pointer to a string in PROGMEM, it does the "special read" (pgm_read_byte) to pull the data from PROGMEM rather than RAM, and the prints it. Note that this takes one additional clock cycle, per byte.
And even more interesting: What happens to literal constants like in this expression a = 5*(10+7) are 5, 10 and 7 really copied to RAM before loading them into registers? I just can't believe that.
No, because they don't have to be. That would compile into a "load literal into register" instruction. That instruction is already in PROGMEM, so the literal is now dealt with. No need to copy it to RAM and then read it back.
I have a lengthy description of these things on the page Putting constant data into program memory (PROGMEM). That has example code for setting up strings, and arrays of strings, reasonably easily.
It also mentions the F() macro which is an easy way of simply printing from PROGMEM:
Serial.println (F("Hello, world"));
A bit of preprocessor complexity lets that compile into a helper function which pulls the bytes in the string from PROGMEM a byte at a time. No intermediate use of RAM is required.
It is easy enough to use that technique for things other than Serial (eg. your LCD) by deriving the LCD printing from the Print class.
As an example, in one of the LCD libraries I wrote, I did exactly that:
class I2C_graphical_LCD_display : public Print
    size_t write(uint8_t c);
The key point here is to derive from Print, and override the "write" function. Now your overridden function does whatever it needs to output a character. Since it is derived from Print you can now use the F() macro. eg.
lcd.println (F("Hello, world"));
Nick Gammon
  • 38,901
