On my Linux Mint 17 Quiana I have manually downloaded and ran several versions of the arduino IDE (1.05 which is in the repo, 1.6.x for some time, now 1.8.3). Things worked like a charm.
Now I am trying to get the IDE 1.8.5 going, but I cannot get the IDE started. Started means: I download, extract the files to a directory and run the install.sh command such that the desktop icon gets created. This finishe with a success message. Now I am clicking on the desktop icon, but nothing happens.
Need to say that the IDE 1.05 which comes as a package with Qiana works just fine. I have run the install.sh of both to and fro, but only the 1.05 will start properly. I checked on the desktop link, the execution rights, user, group etc. They are all looking fine for 1.8.5 but it wont start.
I tried to start the 1.85 arduino IDE from the command line - hoping to get some clue from error messages:
java -DAPP_DIR=/opt/arduino-1.8.5/ Dswing.defaultlaf=com.sun.java.swing.plaf.gtk.GTKLookAndFeel processing.app.Base
--> running this it tells me, that the main class cannot be found.
Any hints where I am going wrong? Are there any config files to be cleared up, paths to be set ...?
You do not need to install Arduino at all. In fact I have never had it work right due to things not being found.
All you need to do is, from a terminal, run the arduino command in the extracted directory:
fred@computer:~/arduino-1.8.5 $ ./arduino
Any errors that then throws will be a clue as to why it doesn't want to work.
Majenko
  • 105,851
  • 82
  • 139
1.05 is the latest available packaged version (and is quite dated).
You can download and (optionally) install the new version. See Installing Arduino IDE on Linux
Either remove (or ignore) the old version. Apart from the additional support the new version supplies, the directories differ - you can either change to the new (recommended) or change the settings.
There is no NEED to "install" the new version. The supplied script DOES NOT install in the traditional sense, it merely installs GUI links to the download.
  • 1,655
  • 29
