I found this code below for the Arduino platform to obtain current measurements from the SCT013 sensor, and I am wondering how can I define the 'delay' or 'frequency' of my readings? I'd be looking for 200Hz.
Code:
#include "EmonLib.h"                   // Include Emon Library
EnergyMonitor emon1;                   // Create an instance
void setup()
  Serial.begin(9600);
  emon1.current(5, 60);             // Current: input pin, calibration.
  //calibration is explained bellow
void loop()
  double Irms = emon1.calcIrms(1480);  // Calculate Irms only
  Serial.print(Irms*230.0);        // Apparent power
  Serial.print(" ");
  Serial.println(Irms);            // Irms
ratchet freak
  • 3,267
you skip reading when the last read is less than 1000/200 = 5ms ago.
unsigned long lastRead;
void loop()
   unsigned long currentMillis = millis();
   if(currentMillis - lastRead >= 5){
      Serial.print(" ");
      lastRead = currentMillis;
ratchet freak
  • 3,267
If you want a 200Hz sample rate this code doesn't work for you.
With this line: double Irms = emon1.calcIrms(1480); you take 1480 samples as fast as Arduino can.
If you want 200Hz sample rate, read analog ping every 5ms using millis() function. And when you have enough samples you can calculate the rms current https://en.wikipedia.org/wiki/Root_mean_square
This is an example code:
unsigned int sample_time = 0;
int readings[200];  //num samples 200
int i = 0;
setup() {
loop() {
    if (millis() - sample_time > 5){
        readings[i] = readAnalog(A0);
        i++;
        sample_time = millis();
    if (i > 200)
         Caculate_Irms();
         i = 0;
jecrespo
  • 75
