I have 8 sets of 8 push buttons. There is a Teensy and a demultiplexer. The demultiplexer has 8 outputs. When an output is selected it is pulled low. Each output is connected to a group of 8 push buttons. The 8 push buttons are then connected to 8 pullup inputs on the Teensy.
Each group of 8 push buttons is connected to a unique demultiplexer output, but all the push buttons are connected to the same 8 inputs on the Teensy. That is, push button #1 in group 1 shares a Teensy input with push button #1 in group 2. The push buttons are isolated from each other with diodes.
I'm using bounce.h for debouncing. It looks for rising and falling edges.
The problem is this:
  • Push button #1 in group #1 is pressed, pulling that input low, causing a falling edge to be detected. This is good.
  • The demultiplexer shifts to group #2, where the #1 button hasn't been pressed, and thus is high.
  • Because both #1 buttons in group #1 and #2 share the same input line, the Teensy sees this change as a rising edge. This is undesired.
What is the better approach to this?
Thanks,
Dan
dda
  • 1,595
Daniel
To do multiplexing with bounce.h you will need one bounce object per button. That's 64 bounce objects for an 8x8 matrix.
Then you only want to update the bounce objects for the group you currently have active.
That is:
  1. Switch to group 1.
  2. Update objects 1-8
  3. Switch to group 2
  4. Update objects 9-16
  5. ... etc ...
You need one object per button so that the internal data can track the state of that specific button, and you only update the 8 objects for the currently selected group otherwise the objects that aren't associated with that group will get confused by incorrect data.
Majenko
  • 105,851
  • 82
  • 139
write your code so it debounces each pin / group of pins separately.
looks like your code used global / static variables.
dannyf
  • 2,813
