I'm trying to create a comma delimited file using this SDFat library
Calling this code creates my file
const char Header[24]="Desired RPM,Output RPM\n";
foo()
  SpeedCache.open("/Speed_Cache.txt",O_CREAT | O_RDWR | O_APPEND);
  SpeedCache.write(Header);
  SpeedCache.sync();
After running, I have a file containing
Desired RPM,Output RPM'\n'
When I call the following function, I want it to add int target and int reference to the bottom of the file.
bool SDClass::SetLine(SdFile Cache,int target, int reference)
  bool good = false;
  char NewLine[32];
  Cache.seekEnd();
  sprintf_P(NewLine,(PGM_P)F("%d,%d\n"),target,reference);
  Serial.println(good=Cache.write(NewLine));
  Cache.sync();
  return good;
On the first call, this works so for an input of SpeedCache,50,100 I get
50,100'\n'
However, if I then write an input of SpeedCache,5,10 I get
5,10'\n'
How do I adjust my function so that I will get:
50,100'\n'
5,10'\n'
ATE-ENGE
  • 941
You just need to open the file in APPEND mode:
O_APPEND
The file is opened in append mode. Before each write, the file offset is positioned at the end of the file, as if with lseek.
You should also pass your file around by reference so it doesn't keep creating new copies of the internal structure:
bool SDClass::SetLine(SdFile &Cache,int target, int reference)
Majenko
  • 105,851
  • 82
  • 139
How do you pass the file by reference?
SdFat sd;
SdFile DataFile;
isSD = DataFile.open(FileName, O_WRITE | O_CREAT | O_AT_END);
Glorfindel
  • 578
