I am using an Arduino Uno and an MCP23008 GPIO pin expander, I have a momentary button connected to GPIO 2 on the MCP23008 and an LED light connected to GPIO 1 on the MCP23008. What I want is for the LED to turn on when the button is pressed down, and off otherwise. The code I currently have is this:
#include "Wire.h" //import Wire library
byte inVal; //declare byte variable
Serial.begin(9600);
Wire.begin();
Wire.beginTransmission(0x20); //MCP23008 i2c addr
Wire.write(0x00); //MCP23008 internal register addr for I.O.dir
Wire.write(00000010); //set all pins as output, except for #2 as input
Wire.endTransmission();
Wire.begin();
Wire.write(0x09); //MCP23008 internal register addr for GPIO access
//Wire.write(0xFF); //set all output pins to HIGH, commented out for now.
Wire.requestFrom(0x20,1); //get one byte of input input from MCP23008
inVal=Wire.read(); //set pyte as variable
//Serial.println(inVal,BIN); //output byte to serial monitor, commented out for now
Serial.println(bitRead(inVal, 1)); //output second bit from byte(1 or 0, for HIGH or LOW, depending on the press of the momentary button.
if((bitRead(inVal, 1)==1)) //if the bit from the button is high,
Wire.write(0x09);
Wire.write(0xFF); //then set all output pins as HIGH
else if((bitRead(inVal, 1)==0)) //if the bit from the button is low,
Wire.write(0x09);
Wire.write(0x00); //then set all output pins as LOW
I don't know as much Arduino as I do Python, and I have even less experience with i2c connections and the Wire library, but this looks to me like it should be working.
The bit printed on the serial monitor is HIGH, until I press the button once, then it stays LOW forever until I modify and re-upload the code to the Arduino. Not sure what's going wrong here. Anything helps, thanks.
