I'm playing around with this udp-example. Both this and the blink-example work perfectly. Now I would like to use the LED to indicate what the ESP is currently doing, as well as reading some data over Serial. My code looks like this:
void setup(){
  Serial.begin(115200);
  Serial.setTimeout(500);
  while(Serial.available()==0){
  String password = Serial.readStringUntil('.');
  Serial.println(password);
  WiFi.begin(ssid.c_str(), password.c_str());
  //pinMode(LED_BUILTIN, OUTPUT);
  while (WiFi.status() != WL_CONNECTED){
    //digitalWrite(LED_BUILTIN, LOW);
    delay(250);
    //digitalWrite(LED_BUILTIN, HIGH);
    delay (250);
  Serial.println("connected");
  Udp.begin(localUdpPort);
It works fine, but if I uncomment the led-lines the serial communication doesn't seem to work anymore. All the stuff that is printed on the Serial Monitor is now messed up (missing characters, ...). Is there a problem with my code or what else could be possible going wrong here?
EDIT: I recently tried the same code again, but used an additional power supply (3.3V, 500mA) for the chip. However, this didn't resolve the problem.
dda
  • 1,595
user2224350
I would bet that the built-in LED pin is also the TX pin for the serial interface.
Check here, LED Pin section: http://www.esp8266.com/wiki/doku.php?id=esp8266_gpio_pin_allocations
LED Pin
GPIO1, which is also TX, is wired to the blue LED on many devices. Note that the LED is active low (connected to Vcc and sinks through the chip to ground) so setting a logical value of 0 will light it up. Since GPIO1 is also the TX pin, you won't be able to blink the LED and perform Serial communications at thew same time unless you switch TX/RX pins.
This would be confirmed if the LED blinks when serial communication is active.
If this is the case you would have to add your own LED on a different pin, or switch the RX/TX pins.
Mazaryk
  • 1,149
