The following image is my connection of l298 with Arduino. enter image description here
This is the program.
int ENA = 10; // MCU PWM Pin 10 to ENA on L298n Board
int IN1 = 9;  // MCU Digital Pin 9 to IN1 on L298n Board
int IN2 = 8;  // MCU Digital Pin 8 to IN2 on L298n Board
int ENB = 5;  // MCU PWM Pin 5 to ENB on L298n Board
int IN3 = 7;  // MCU Digital pin 7 to IN3 on L298n Board
int IN4 = 6;  // MCU Digital pin 6 to IN4 on L298n Board
void setup()
pinMode(ENA, OUTPUT); //Set all the L298n Pin to output
pinMode(ENB, OUTPUT);
pinMode(IN1, OUTPUT);
pinMode(IN2, OUTPUT);
pinMode(IN3, OUTPUT);
pinMode(IN4, OUTPUT);
void DRIVEONE()
// Run the motors on both direction at fixed speed
digitalWrite(IN1, HIGH); // Turn HIGH motor A
digitalWrite(IN2, LOW);
analogWrite(ENA, 200); // TO set the turning speed to 200 out of possible
range 0 to 255
digitalWrite(IN3, HIGH); // turn HIGH motor B
digitalWrite(IN4, LOW);  // To set the turning speed to 200 out of possible
range 0 to 255
analogWrite(ENB, 200);
delay(2000);  // Delay to 2 seconds
void loop()
DRIVEONE();
delay(100);
The program seems to work fine but the motors run only when I touch all the 15 pins in L298 as shown in the second image. I don't understand why the motors aren't running without touching those 15 pins.
I have connected the L298 to a 12V rechargeable battery and Arduino to a 9V battery. Please help me understand what is wrong here. Thank you.
Dixit
Your schematic does not show a connection from the ground line of the 12V battery to the GND connection on the Arduino. This is required.
Chris Stratton
  • 5,411
  • 40
jose can u c
  • 6,974
