I would really appreciate any help, my home project has been put on hold for weeks as I haven't been able to figure this out. In a nutshell, I'm connecting to my wifi network, measuring temperature from a sensor, and sending that temperature data to a server via a HTTP Request. All of that stuff works.
I have it in a loop, and on the 3rd HTTP request I get 'Connection Failed' when it's trying to client.connect(server, 80) - I don't understand why it fails. I've tried adding client.stop() and client.flush() after each HTTP request, but nothing fixes it. Below is my sketch file with some of the temperature code removed to make it easier to read
#include <SPI.h>
#include <WiFi101.h>
#include <string.h>
#include <stdlib.h>
#include <OneWire.h>
#include <DallasTemperature.h>
//WiFi Client Setup
char ssid[] = "HIDDEN";    //  your network SSID (name)
char pass[] = "HIDDEN";       // your network password
int status = WL_IDLE_STATUS;    // the WiFi radio's status
char server[] = "HIDDEN";
WiFiClient client;
// Setup for temperature sensor
#define ONE_WIRE_BUS A5
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
DeviceAddress insideThermometer;
  Serial.begin(9600);
  WiFi.setPins(8,2,A3,-1);
  while (!Serial) {
    Serial.println("Waiting for serial");
  //Connect to wifi shield
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("WiFi shield not present");
    while (true);
  wifiConnect();
  sensors.begin();
  while (client.available()) {
    char c = client.read();
    Serial.write(c);
  Code to get temperature here
  httpRequest(temp);
  delay(10000); // 5min
void httpRequest(String temp) {
  String request = "POST /api/webhooks/temp?temperature=" + temp + " HTTP/1.1";
  // if there's a successful connection:
  if (client.connect(server, 80)) {
    Serial.println("connected to server");
    client.println(request);
    client.println("Authorization: Token HIDDEN");
    client.println("Host: HIDDEN");
    client.println("Connection: close");
    client.println();
  else {
    Serial.println("Connection failed");
void wifiConnect() {
  //Attempt to connect to WiFi network:
  while ( status != WL_CONNECTED) {
    Serial.print("Attempting to connect to WPA SSID: ");
    Serial.println(ssid);
    status = WiFi.begin(ssid, pass);
    delay(1000);
  Serial.println("You're connected to the network");
hummmingbear
  • 141
I tried changing the strings to char's, that didn't work. Verified that it was closing connections with the server, check.
Was reading around and saw someone who tried a soft reset of the wifi client here. I added the following to the end of my httpRequest() method
client.stop();
WiFi.end();
delay(10);
And now it's working just fine. I'm going to have it run all night and see if there are any issues, but it's definitely an improvement as I can make more than 3 requests :|
This seems like a terrible work around. Clearly something isn't getting reset after each HTTP request on the wifi client, and this (right now) is the only way to solve it. I'd really love any other feedback on a better ways to solve it. Seems like some issues with the WiFi101 Library.
hummmingbear
  • 141
