I've connected a real time clock ZS-042 to my Arduino Uno. I tried to set the time, using an example from DS1307RTC library. Here is my code:
#include <DS1307RTC.h>
#include <Time.h>
#include <Wire.h>
*const* char *monthName[12] = {
"Jan", "Feb", "Mar", "Apr", "May", "Jun",
"Jul", "Aug", "Sep", "Oct", "Nov", "Dec"
tmElements_t tm;//it says that problem is in here
bool parse=false;
bool config=false;
// get the date and time the compiler was run
if (getDate(__DATE__) && getTime(__TIME__)) {
parse = true;
// and configure the RTC with this info
if (RTC.write(tm)) {
config = true;
Serial.begin(9600);
while (!Serial) ; // wait for Arduino Serial Monitor
delay(200);
if (parse && config) {
Serial.print("DS1307 configured Time=");
Serial.print(__TIME__);
Serial.print(", Date=");
Serial.println(__DATE__);
} else if (parse) {
Serial.println("DS1307 Communication Error :-{");
Serial.println("Please check your circuitry");
} else {
Serial.print("Could not parse info from the compiler, Time=\"");
Serial.print("\", Date=\"");
Serial.print(__DATE__);
Serial.println("\"");
bool getTime(const char *str)
int Hour, Min, Sec;
if (sscanf(str, "%d:%d:%d", &Hour, &Min, &Sec) != 3) return false;
tm.Hour = Hour;
tm.Minute = Min;
tm.Second = Sec;
return true;
bool getDate(const char *str)
char Month[12];
int Day, Year;
uint8_t monthIndex;
if (sscanf(str, "%s %d %d", Month, &Day, &Year) != 3) return false;
for (monthIndex = 0; monthIndex < 12; monthIndex++) {
if (strcmp(Month, monthName[monthIndex]) == 0) break;
if (monthIndex >= 12) return false;
tm.Day = Day;
tm.Month = monthIndex + 1;
tm.Year = CalendarYrToTm(Year);
return true;
and this is my output:
Arduino: 1.6.12 (Windows 10), Плата:"Arduino/Genuino Uno"
In file included from C:\Users\6939~1\AppData\Local\Temp\arduino_modified_sketch_566010\SetTime.ino:1:0:
C:\Users\папа\Documents\Arduino\libraries\DS1307RTC/DS1307RTC.h:19:22: error: 'tmElements_t' has not been declared
static bool read(tmElements_t &tm);
C:\Users\папа\Documents\Arduino\libraries\DS1307RTC/DS1307RTC.h:20:23: error: 'tmElements_t' has not been declared
static bool write(tmElements_t &tm);
SetTime:10: error: 'tmElements_t' does not name a type
tmElements_t tm;
C:\Users\6939~1\AppData\Local\Temp\arduino_modified_sketch_566010\SetTime.ino: In function 'void setup()':
SetTime:21: error: expected primary-expression before ')' token
C:\Users\6939~1\AppData\Local\Temp\arduino_modified_sketch_566010\SetTime.ino: In function 'bool getTime(const char*)':
SetTime:54: error: expected unqualified-id before '.' token
tm.Hour = Hour;
SetTime:55: error: expected unqualified-id before '.' token
tm.Minute = Min;
SetTime:56: error: expected unqualified-id before '.' token
tm.Second = Sec;
C:\Users\6939~1\AppData\Local\Temp\arduino_modified_sketch_566010\SetTime.ino: In function 'bool getDate(const char*)':
SetTime:71: error: expected unqualified-id before '.' token
tm.Day = Day;
SetTime:72: error: expected unqualified-id before '.' token
SetTime:73: error: expected unqualified-id before '.' token
exit status 1
