i have problem with initialization DFRobot SIM808 actually when i try to recieve gps data by SoftwareSerial only it does works (i mean examples based on sending and reading command to and from serial's), and recieve data but very long string of data and i need only Latitude and Longitude and i think using DFRobot will be the easiest way to extract the data i need. So the simple test program like this one is not working:
### Get GPS data
1. This example is used to test SIM808 GPS/GPRS/GSM Shield's reading GPS data.
2. Open the SIM808_GetGPS example or copy these code to your project
3. Download and dial the function switch to Arduino
4. open serial helper
4. Place it outside, waiting for a few minutes and then it will send GPS data to serial
create on 2016/09/23, version: 1.0
by jason
#include <DFRobot_sim808.h>
#include <SoftwareSerial.h>
#define PIN_TX 7
#define PIN_RX 8
SoftwareSerial mySerial(PIN_TX,PIN_RX);
DFRobot_SIM808 sim808(&mySerial);//Connect RX,TX,PWR,
mySerial.begin(9600);
Serial.begin(9600);
//******** Initialize sim808 module *************
while(!sim808.init()) {
delay(1000);
Serial.print("Sim808 init error\r\n");
//************* Turn on the GPS power************
if( sim808.attachGPS())
Serial.println("Open the GPS power success");
else
Serial.println("Open the GPS power failure");
//************** Get GPS data *******************
if (sim808.getGPS()) {
Serial.print(sim808.GPSdata.year);
Serial.print("/");
Serial.print(sim808.GPSdata.month);
Serial.print("/");
Serial.print(sim808.GPSdata.day);
Serial.print(" ");
Serial.print(sim808.GPSdata.hour);
Serial.print(":");
Serial.print(sim808.GPSdata.minute);
Serial.print(":");
Serial.print(sim808.GPSdata.second);
Serial.print(":");
Serial.println(sim808.GPSdata.centisecond);
Serial.print("latitude :");
Serial.println(sim808.GPSdata.lat);
Serial.print("longitude :");
Serial.println(sim808.GPSdata.lon);
Serial.print("speed_kph :");
Serial.println(sim808.GPSdata.speed_kph);
Serial.print("heading :");
Serial.println(sim808.GPSdata.heading);
Serial.println();
//************* Turn off the GPS power ************
sim808.detachGPS();
