I hope this the right place to post this question :)
I'm trying to display a menu on a SSD1351 OLED display, to which I communicate with U8glib. I'm trying to obtain an Init screen, then, with a long press on a button (Menu), get in to a menu with 3 options (let's say option1, option2 and back). I got it working this way:
#include <Button.h>  // https://github.com/JChristensen/Button.git
#include "U8glib.h"
#include <Wire.h>
#define PULLUP true
#define INVERT true
#define DEBOUNCE_MS 20
Button ok(2, PULLUP, INVERT, DEBOUNCE_MS);
Button menu(5, PULLUP, INVERT, DEBOUNCE_MS);
Button down(3, PULLUP, INVERT, DEBOUNCE_MS);
Button up(4, PULLUP, INVERT, DEBOUNCE_MS);
U8GLIB_SSD1351_128X128_332 u8g(8, 9, 7);
uint8_t screen = 0;
uint8_t menu_current = 0;
  u8g.setFont(u8g_font_unifont);
  u8g.setDefaultForegroundColor();
  drawScreen();
  ok.read();
  menu.read();
  up.read();
  down.read();
  if (menu.pressedFor(1000) && screen == 0) {
    screen = 1;
    menu_current = 0;
    drawScreen();
  if (screen == 1) {
    if (up.wasReleased()) {
      if (menu_current > 0) {
        menu_current--;
        drawScreen();
    if (down.wasReleased()) {
      if (menu_current < 2) {
        menu_current++;
        drawScreen();
    if (ok.wasReleased()) {
      switch (menu_current) {
        case 0:
          screen = 2;
          break;
        case 1:
          screen = 3;
          break;
        case 2:
          screen = 0;
          break;
          break;
      drawScreen();
  if (screen == 2 || screen == 3) {
    if (menu.wasReleased()) {
      screen = 1;
      menu_current = 0;
      drawScreen();
void drawScreen() {
  u8g.firstPage();
  do {
    whatToDraw();
  } while (u8g.nextPage());
void whatToDraw() {
  switch (screen) {
    case 0: {
        u8g.drawStr(0, u8g.getFontLineSpacing(), F("Init"));
      } break;
    case 1: {
      const char *menu_strings[3] = { "option1", "option2", "Back" };
      uint8_t i, h;
      u8g_uint_t w, d;
      u8g.setFontRefHeightText();
      u8g.setFontPosTop();
      h = u8g.getFontAscent() - u8g.getFontDescent();
      w = u8g.getWidth();
      for ( i = 0; i < 3; i++ ) {
        d = (w - u8g.getStrWidth(menu_strings[i])) / 2;
        if ( i == menu_current ) {
          u8g.drawBox(0, i * h + 1, w, h);
          u8g.setDefaultBackgroundColor();
        u8g.drawStr(d, i * h, menu_strings[i]);
    break;
    case 2: {
      u8g.drawStr(0, u8g.getFontLineSpacing(), F("Option1"));
    break;
    case 3: {
      u8g.drawStr(0, u8g.getFontLineSpacing(), F("Option2"));
    break;
    break;
Everything seems to be working except the back option: when I select it, the display gets blanked instead of visualizing screen 0 ("Init"). Variables seem to be set correctly. Does anybody have an idea why this isn't working?
Thank you :)
Dario
EDIT: copied the whole sketch as requested :)
dda
  • 1,595
noospy
Summary: I tested @noospy project (with some modifications) and it works flawlessly.
Menu and buttons
I had to rename Button.h to ButtonM.h due name conflict with another button library. Also, I'm using new version U8g2, so I had to change some types and eliminate some calls. Finally, I used the I2C version of the OLED screen.
This is my adapted code:
#include <ButtonM.h>  // https://github.com/JChristensen/Button.git
#include "U8g2lib.h"
#include <Wire.h>
#define PULLUP true
#define INVERT true
//U8GLIB_SSD1351_128X128_332 u8g(8, 9, 7);
// Screen
U8G2_SSD1306_128X64_NONAME_1_HW_I2C u8g(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
uint8_t screen = 0;
    u8g.begin(); // Added
//  u8g.setDefaultForegroundColor();
    drawScreen();
    ok.read();
    menu.read();
    up.read();
    down.read();
        screen = 1;
        menu_current = 0;
        drawScreen();
    if (screen == 1) {
                menu_current--;
                drawScreen();
                menu_current++;
                drawScreen();
                case 0:
                    screen = 2;
                    break;
                case 1:
                    screen = 3;
                    break;
                case 2:
                    screen = 0;
                    break;
                break;
            drawScreen();
            screen = 1;
            menu_current = 0;
            drawScreen();
void drawScreen() {
    u8g.firstPage();
    do {
        whatToDraw();
    } while( u8g.nextPage() );
void whatToDraw() {
    switch (screen) {
        case 0: {
            u8g.drawStr(0,getFontLineSpacing(),"Init");
        } break;
        case 1: {
            uint8_t i, h;
            int w, d;
            h = u8g.getFontAscent()-u8g.getFontDescent();
            w = u8g.getWidth();
            for( i = 0; i < 3; i++ ) {
                d = (w-u8g.getStrWidth(menu_strings[i]))/2;
                    u8g.drawBox(0, i*h+1, w, h);
//                    u8g.setDefaultBackgroundColor();
                u8g.drawStr(d, i*h, menu_strings[i]);
         } break;
         case 2: {
             u8g.drawStr(0,getFontLineSpacing(),"Option1");
         } break;
         case 3: {
             u8g.drawStr(0,getFontLineSpacing(),"Option2");
         } break;
         break;
int getFontLineSpacing() {
  return 24;
Hardware
  1. Arduino Pro Mini 3.3v 8MHz
  2. 1306 0.96 inch White Color I2C IIC Communication 128 * 64 OLED Display.
  3. 4x push buttons with 1K pullup resistors.
So, I don't know what your problem is, but your code is impecable.
You can consider using one of the existing menu libraries, there are some available on github. Just pick the one that best fits your needs
https://github.com/search?utf8=%E2%9C%93&q=arduino+menu&type=
neu-rah
  • 149
