I'm sending a string from my sketch over Serial port as follows:
Serial.println(F("Found ILI9341 LCD driver"));
On the other side, I have a nodejs app using the serialport npm module, with something like this:
var SerialPort = require('serialport')
var serialPort = new SerialPort('/dev/ttyACM1', {
  baudrate: 9600
// it opens the connection and register an event 'data'
serialPort.on('open', function () {
  console.log('Communication is on!')
// when your app receives data, this event is fired
// so you can capture the data and do what you need
serialPort.on('data', function (data) {
  console.log('data received: ' + data)
Communication works, but on nodejs side I get the output chunked, as if it had line breaks, like this:
data received: Pa
data received: int!
data received:
data received: Fou
data received: nd I
data received: LI93
data received: 41 L
data received: CD d
data received: rive
data received: r
Why does this happen?
jotadepicas
  • 326
It seems I needed to add a parser to SerialPort nodejs module, in order to specify how the input should be treated.
I changed my code to this:
var Readline = SerialPort.parsers.Readline
var serialPort = new SerialPort('/dev/ttyACM0', {
  baudrate: 9600
var parser = new Readline()
serialPort.pipe(parser)
parser.on('data', function (data) {
Basically, I'm specifying a Readline parser, which matches with the Serial.println function calls on my arduino sketch. Now the console output works as expected:
data received: Found ILI9341 LCD driver
jotadepicas
  • 326
