I'm trying to connect Arduino Leonardo to an Android tablet. I would like to make the Arduino send commands (using pushbuttons or a slider for example) to the tablet to switch between pages, to select a file on the desktop, to scroll up and down the screen, etc.
Perhaps this is not exactly what you are looking for, but from your examples it seems like using navigational commands from the keayboard/mouse would accomplish a lot of what you are requesting.
Android has USB HID support from honecomb, so you should be able to create a sketch to emulate a keyboard and mouse based on the IO data and it should work with your android device just by plugging the USB cable (if emulating a mouse, it will display the mouse cursor as soon as it is connected).
- 151
- 2
First, get a Lightblue Bean, http://punchthrough.com/bean/
It has everything you need: - arduino - bluetooth - API - code example - android sdk - ...
Develop your product using this platform.
If you want to scale and build your own platform, then you will have a foundation to validate your work.
- 109
- 2
It is a good idea to use a LightBlue Bean, only if you are using the Android SDK! https://bitbucket.org/littlerobots/beanlib
You can read more about the SDK, and get advice from people who are actually using it. http://beantalk.punchthrough.com/t/announcing-unofficial-android-sdk/394
- 11
Android code:
function OnStart() {
//Create a layout with objects vertically centered.
lay = app.CreateLayout("linear", "VCenter,FillXY")
//Create a toggle button.
btn = app.CreateToggle("LED On/Off", 0.4)
btn.SetOnTouch(btn_OnTouch)
lay.AddChild(btn)
//Add layout to app.
app.AddLayout(lay)
//Create USB serial object.
usb = app.CreateUSBSerial()
if (!usb) {
app.ShowPopup("Please connect your Arduino and restart")
return;
usb.SetOnReceive(usb_OnReceive)
app.ShowPopup("Connected")
//Called when user touches our toggle button.
function btn_OnTouch(isChecked) {
if (!usb) return;
//Send LED command to Uno.
if (isChecked) usb.Write("ledh")
else usb.Write("ledl")
//Called when we get data from Espruino.
function usb_OnReceive(data) {
console.log(data)
Arduino code:
pinMode(2,1);
serial.begin(9600);
loop() {
if (serial.Read()="ledh) {
digitalWrite(2,1);
if (serial.Read()="ledl) {
digitalWrite(2,0);
- 1,795
- 3
- 12
- 24
