I'm building a complex I2C-based networking protocol and have noticed that the Wire.onReceive() handler is called both for I2C read and write operations. When the master writes to the slave, it is called as you'd expect. But it also seems to be invoked when the master reads from the slave which is unexpected.
Ideally, I'd like a transaction with both a read and a write - e.g. the master writes a value (for instance a variable argument) and then reads back from the slave the result (for instance, the lookup of that variable.)
Compiled on the SAMD21 ArduinoCore, the following programs generate this result:
1400,700
>>> x is
<<< hello
>>> x is
<<< hello
1404,702
>>> x is
Showing that the onReceive is called twice as often as onRequest.
I don't see this behavior documented anywhere.
Master:
#include </p>
void setup()
  Wire.begin();        // join i2c bus (address optional for master)
  Serial.begin(9600);  // start serial for output
void loop()
  Wire.beginTransmission(4); // transmit to device #4
  Wire.write("foobar");        // sends five bytes
 // Wire.write(3);              // sends one byte
  Wire.endTransmission(true);    // stop transmitting
  Wire.requestFrom(4, 6);    // request 6 bytes from slave device #2
  while(Wire.available())    // slave may send less than requested
    char c = Wire.read(); // receive a byte as character
    Serial.print(c);         // print the character
  delay(500);
Slave
#include <Wire.h>
void setup()
  Wire.begin(4);                // join i2c bus with address #4
  Wire.onReceive(receiveEvent); // register event
  Wire.onRequest(requestEvent);
long inCount = 0;
long outCount = 0;
void loop()
  char c[200];
  snprintf( c, 200, "%d,%d\n", inCount, outCount );
  Serial.print( c );
  delay(1000);
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
void receiveEvent(int howMany)
inCount++;
  Serial.print( ">>> ");
  while(1 < Wire.available()) // loop through all but the last
    char c = Wire.read(); // receive byte as a character
  Serial.println();         // print the integer
// function that executes whenever data is requested by master
void requestEvent()
  Serial.println( "<<< hello ");
  outCount++;
  Wire.write("hello "); // respond with message of 6 bytes
                       // as expected by master
VE7JRO
  • 2,515
  • 29
Jeremy Gilbert
  • 274
