I have been controlling my servomotors for a while now only using pin 0. After some research, it has became apparent to me that the ports with ~ are the PWM pins.
I thought that all pins sent out PWM signals, therefore the motor was able to move back and forth. Now I'm really confused as to how the motor was able to turn without using a ~ pin like pin 5.
Can someone explain why I should or should not use PWM signal when controlling a motor?
The Guy with The Hat
  • 5,292
  • 30
Fraïssé
  • 905
Servos does not use PWM, it uses PPM:
  • PWM = Pulse width modulation, The pulse start at 0ms, and is high for the percentage of the time compared to the percentage of the voltage you want, 5v signal, if you want 1v, the pulse is 20ms High and 80ms Low.
  • PPM = Pulse position modulation, The pulse length is always 5ms High and 95ms low, but the interesting part is if high starts after 5ms or 50ms (or any other).
So PWM is to lower voltage, PPM is a signal pulse.
This means that no matter what port you are using on the arduino you are able to control a servo since you only need High or Low, and not a lower voltage.
What you need to be aware of in this case is on the arduino is a PPM signal is using up a timer. The arduino has 3 timers where of 2 is available, one is used internally. Though there is code where you can attach up to 3 servos on the same internal timer.
  • 5,292
  • 30
Magic-Mouse
  • 604
