I'm working on a project where I have to communicate to several devices over I2C using a Genuino 101. Now I'm trying to get data off the bus but wire.available() stays at 0, even though my trace clearly shows there's data being sent.
with the following timings
Because the wire is never available my readbuf will always be empty.
Rdbuf[0] is: 0 Hex is: 0
Rdbuf[1] is: 0 Hex is: 0
I'm using the following code to read from the I2C bus.
void i2cRead(unsigned char device, unsigned char memory, int len, unsigned char * rdBuf) {
ushort memstart = memory;
bool available = true;;
while (len > 0 && available) {
available = false;
ushort blockSize;
/*If the number of bytes is smaller than the block size, read that size*/
(len < RD_BLCK_SIZE) ? blockSize = len : blockSize = RD_BLCK_SIZE;
Wire.beginTransmission(static_cast<int>(device));
//send i2c START command
Wire.write(memory);
//Write memory address
Wire.endTransmission();
//send i2c STOP command
Wire.requestFrom(static_cast<int>(device), blockSize,true);
//Request blockSize bytes from the device
/* for every byte in the response add that byte to the read buffer */
while (Wire.available() && (len != 0)) {
available = true;
rdBuf[memory - memstart] = Wire.read();
memory++;
len--;
I'm not quite sure what I'm doing wrong, any help would be much appreciated.
Edit:
Below is an image of the current (minimal) setup. On the left there's the board with the ADC and multiplexer visible.
The third set of wires goes to my protocol analyzer.
