I am trying to use D0/D1 as normal IO pins but DigitalWrite does not work as on an Arduino UNO.
I know the SAMD21G has SERCOM but I can't seem to find an example of not using D0/D1 as an UART port.
EDIT ** Code I have tried:
#define MYMASK 0x00000C00
  REG_PORT_DIRSET0 = MYMASK; // Direction set to OUTPUT
  REG_PORT_OUTSET0 = MYMASK; // set state of pin(s) to TRUE (HIGH)
  delay(1000);
  REG_PORT_OUTCLR0 = MYMASK; // set state of pin(s) to FALSE (LOW)
PhillyNJ
  • 1,178
Bertus Kruger
  • 233
You can do this by simply calling the right registers:
Example 1, using a MASK
D0/D1 are mapped to to PA10 & PA11 on the M0
/* The following ports where selected
    PORT_PA11
    PORT_PA10
int main (void)
    system_init();
    //REG_PORT_OUTCLR0 = MYMASK; // set state of pin(s) to FALSE (LOW)
    while(1){
Here is another simple example:
    PORT_PA11
    PORT_PA10
#define LED1 PORT_PA10
#define LED2 PORT_PA11
int main (void)
    system_init();
    REG_PORT_DIRSET0 = LED1 | LED2; // Direction set to OUTPUT
    REG_PORT_OUTSET0 = LED1 | LED2; // set state of pin(s) to TRUE (HIGH)
    //REG_PORT_OUTCLR0 = LED1 | LED2; // set state of pin(s) to FALSE (LOW)
    while(1){
In the Arduino IDE you can do something like:
   delay(1000);
   delay(1000);
PhillyNJ
  • 1,178
