I have an Intel Galileo (1st gen) and a servo motor (Tower Pro SG90).
My problem: my servo moves only in one direction and it doesn't turn back. I want to perform a movement from 0° to 90° and then from 90° to 0° again.
At the moment, I have just tried the official arduino snippet for servo motor that should perform a similar movement. But, as said before, the servo doesn't turn back.
Here the code
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// a maximum of eight servo objects can be created
int pos = 0; // variable to store the servo position
void setup()
myservo.attach(9); // attaches the servo on pin 9 to the servo object
void loop()
for(pos = 0; pos < 180; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
for(pos = 180; pos>=1; pos-=1) // goes from 180 degrees to 0 degrees
Obviously I have made the attachments like on arduino tutorial.
Every help will be greatly appreciated! :) Thanks in advance
