I want to get as low power use during sleep as possible with an Adafruit Trinket. Based on results presented on various places in the internet (blogs etc), I expect to be able to go down to 50 - 100 micro amps on the ATTiny85 of the Trinket. I am aware of the fact that using a board such as Trinket may add a bit of consumption, and I physically removed the power LED and the power regulator. I am feeding 5V directly on the 5V pin.
I am using the simplest sketch I can think about for low power, with nothing connected to any pin:
#include <avr/sleep.h>          // library for sleep
#define adc_disable() (ADCSRA &= ~(1<<ADEN)) // disable ADC (before power-off)
  delay(10000);
  // power_all_disable();
  set_sleep_mode(SLEEP_MODE_PWR_DOWN);
  adc_disable();
  sleep_enable();
  sleep_mode();
But I cannot get less than around 1.3 milli amps consumption during sleep. Do you know what may be the cause of using ~1mA instead of ~100 microA? Any idea how I can decrease this further?
Edit 1: it should be even much less than ~50 - 100 micro Amps: ATtiny85: Power consumption vs clock speed ; even though this the libraries are maybe primary intended for the ATMega328P, it looks like it should work also with ATTiny85 as well: http://www.technoblogy.com/show?KX0
Edit 2: I had an ATMega328P-based Adafruit Metro Mini lying around. I took away the ON LED, and then using exactly this sketch, feeding power directly on the 5V pin of the Metro Mini, leads to a power consumption of around 150 micro Amps during sleep, which is more like what I expect. Strange it is 10 times more with the ATtiny while it should have been less (?). Am I missing something or is it maybe just broken library on ATtiny? This is a bit ironic, as I went for the lesser ATtiny85 based board for saving current compared with the ATMega328P...
Zorglub29
  • 129
Please have a look at the schematics:
https://cdn-learn.adafruit.com/assets/assets/000/010/774/original/adafruit_products_trinket5.png?1378223478
The USB connector uses a resistor (1500 Ohms) against the 5V net and a 3.6 Volt Z-Diode on it's (D-)-Pin. In addition to the current that is drawn by the microcontroller, this part of the circuit draws some extra current. (5[V] - 3.6[V])/1500[ohm] = 0.0009333... ~= 0.001 [A].
Even though I'm not completely sure without making some tests, that seams plausible to me.
EDIT (Answer to the OPs comment below.)
The schematics uses a normal diode symbol but has a 3.6 Volt label next to it. I assume that it should be a Zener diode with a reverse voltage drop of 3.6 Volts. If I'm right, the Diode is used to limit the 5 Volts to 3.6 Volts (for what reason ever). The Zener Diode effectively limits the Voltage over it to 3.6 Volts. The rest of the voltage of 5 Volts must be dropped over the resistor. i.e. 5V - 3.6V = 1.4V. This voltage drop tells us by Ohms Law that the current through the resistor is:
I = U / R
I[A] = 1.4[V] / 1500[Ohm]  = (about) 1 mA.
This value is very reasonable for your observations and the current is drawn from the 5V connect, hence you can measure it, even if you would desolder the microcontroller.
Peter Paul Kiefer
  • 1,893
