I want to produce a digital sine wave, send it to DAC0, and then receive it back as input on A0 and plot the graph. I am using an Arduino Due. I wrote the following code:
#define maxSamplesNum 120
#define Sample 50000000/maxSamplesNum // sample for the 50Hz signal expressed in microseconds
static int Table[maxSamplesNum] = // lookup table for sine wave table
0x7ff, 0x86a, 0x8d5, 0x93f, 0x9a9, 0xa11, 0xa78, 0xadd, 0xb40, 0xba1,
0xbff, 0xc5a, 0xcb2, 0xd08, 0xd59, 0xda7, 0xdf1, 0xe36, 0xe77, 0xeb4,
0xeec, 0xf1f, 0xf4d, 0xf77, 0xf9a, 0xfb9, 0xfd2, 0xfe5, 0xff3, 0xffc,
0xfff, 0xffc, 0xff3, 0xfe5, 0xfd2, 0xfb9, 0xf9a, 0xf77, 0xf4d, 0xf1f,
0xeec, 0xeb4, 0xe77, 0xe36, 0xdf1, 0xda7, 0xd59, 0xd08, 0xcb2, 0xc5a,
0xbff, 0xba1, 0xb40, 0xadd, 0xa78, 0xa11, 0x9a9, 0x93f, 0x8d5, 0x86a,
0x7ff, 0x794, 0x729, 0x6bf, 0x655, 0x5ed, 0x586, 0x521, 0x4be, 0x45d,
0x3ff, 0x3a4, 0x34c, 0x2f6, 0x2a5, 0x257, 0x20d, 0x1c8, 0x187, 0x14a,
0x112, 0xdf, 0xb1, 0x87, 0x64, 0x45, 0x2c, 0x19, 0xb, 0x2,
0x0, 0x2, 0xb, 0x19, 0x2c, 0x45, 0x64, 0x87, 0xb1, 0xdf,
0x112, 0x14a, 0x187, 0x1c8, 0x20d, 0x257, 0x2a5, 0x2f6, 0x34c, 0x3a4,
0x3ff, 0x45d, 0x4be, 0x521, 0x586, 0x5ed, 0x655, 0x6bf, 0x729, 0x794
int i = 0;
int sample;
int sensorPin = A0;
int sensorValue = 0;
Serial.begin(9600);
analogWriteResolution(12); // set the analog output resolution to 12 bit (4096 levels)
analogReadResolution(12); // set the analog input resolution to 12 bit
sample = 50;
analogWrite(DAC0, Table[i]); // write the selected waveform on DAC0
i++;
if (i == maxSamplesNum) // Reset the counter to repeat the wave
i = 0;
delayMicroseconds(sample); // Hold the sample value for the sample time
sensorValue = analogRead(sensorPin);
I want to create a 3.3 V (P-P) sine wave but I don't how to set the amplitude in this wave.
Also I would like to redirect the sine wave output from DAC0 to the A0 Pin and plot the graph to check if generating the sine wave was successful. How do I plot the graph ?
I uploaded the program but there was no result. I tried to read data from A0, but there wasn't any output. What am I doing wrong?
