I've had a bit of experience with DHT11/DHT22 sensors in a greenhouse environment, and believe that when they get wet they stop working altogether.
Are there any low cost humidity sensors that I can hook up to an Arduino that don't suffer from this problem, or is there a way to protect these sensors from damage when near water? (I'm not talking about immersing them in water - but do expect condensation to get sprayed with water and/or get condensation on them from time-to-time).
Am I correct that the SHTxx sensors are able to withstand this kind of abuse, and that these sensors are about 5-10 times the cost of DHT sensors? (I did not want to spend that much, but if it's the only possibility I might consider it).
dda
  • 1,595
davidgo
  • 175
2022 UPDATE: After ~5 years since I wrote this answer, I'd like to mention that I don't like BME280 anymore, because of its (1) inaccuracy and (2) requirement to make some non-trivial computations to get real values from sensor's data. If you already got a BME280 and your project requires only approximate values of temperature/humidity, it will work, go ahead. Otherwise, consider using SHT3x!
See also this, this, and especially this one.
Original answer:
I'd consider using Bosch BME280 digital sensor. Although it's a bit expensive, it has very good sensitivity, precision and amazingly fast response for humidity changes (for ex. in my project it detects dry human hand lying in 2" away within a 1-2 seconds).
So its features make possible to put it into an enclosure to avoid direct water contact with water spays and it'll still be very responsive for greenhouse needs, I suppose. Datasheet warns:
Liquids shall not come into direct contact with the device.
Also, I'd use electronic-friendly protective acrylic lacquer (Plasticote 70 for instance) and put two layers to sensor's PCB, avoiding small black tiny vent hole on the chip itself: BME280
UPD: Here's DHT11 with cover removed: DHT11 inside
It might be the easiest and cheapest solution to cover all internal contacts and IC (avoiding humidity sensor's stripes) of DHT11 with Plasticote 70.
finnan
  • 302
